damientt Posted December 6, 2007 Share Posted December 6, 2007 I've just fitted a DVD player to the car but there's a slight hitch. It will play DVD soundtracks but doesn't display the video. I think this might be because I didn't connect up the parking sensor wire from the unit to the handbrake wiring harness. Arse!! If I connect the wire a ground source will this solve the problem or do I need to do something else? I don't want to connect it to the handbrake, partly because I never use it. Quote Link to comment Share on other sites More sharing options...
MARCUS1979 Posted December 6, 2007 Share Posted December 6, 2007 If you just ground that wire it should work fine mate Quote Link to comment Share on other sites More sharing options...
brians25 Posted December 7, 2007 Share Posted December 7, 2007 yeah earth the wire, , mines is the same its supposed to be so as you can't play video an drive at the same time, stuff that, just earth it an all will be fine Quote Link to comment Share on other sites More sharing options...
Mr. Fish Posted December 7, 2007 Share Posted December 7, 2007 yup, like people have said just earth it, and it will be fine Quote Link to comment Share on other sites More sharing options...
damientt Posted December 7, 2007 Author Share Posted December 7, 2007 I've earthed it and it works. Hurrah. Quote Link to comment Share on other sites More sharing options...
boombastictiger Posted December 8, 2007 Share Posted December 8, 2007 As i started a thread the other day ALL U HAVE TO DO IS EARTH IT , as per advice from the guys on here, take of the center console where there gear lever is, there are screws all around the place, Trim a bit of the parking sensor wire, unloosen a screw, put the wire under the screw and then tighten the screw ontop,......ur dvd player will work then..... Quote Link to comment Share on other sites More sharing options...
Al Massey Posted December 8, 2007 Share Posted December 8, 2007 unloosen a screw, and then tighten the screw ontop. isnt that the same thing? lol Quote Link to comment Share on other sites More sharing options...
