SILKYSMOOTH Posted December 1, 2007 Share Posted December 1, 2007 I have an annoying sqeeking sound coming from 1 or 2 of the wheels, it only happens when i'm slowly edging forward in trafiic upto 10 mph....comes and goes. I recently changed all the pads and discs and thought it would solve it (it did improve alot), but I did not fit new anti-squeel shims and just cleaned them up and fitted them back again, is this the problem? and do toyota sell them? Link to comment Share on other sites More sharing options...
Nic Posted December 1, 2007 Share Posted December 1, 2007 04945-14110 Front Brake Shim Kit Link to comment Share on other sites More sharing options...
SILKYSMOOTH Posted December 1, 2007 Author Share Posted December 1, 2007 04945-14110 Front Brake Shim Kit Thanks NIC Do you think this is the cause of the squeeking/squeeling noise? Link to comment Share on other sites More sharing options...
SILKYSMOOTH Posted February 8, 2008 Author Share Posted February 8, 2008 04945-14110 Front Brake Shim Kit Just got the Anti Squeal shims in from Toyota, but they look massive. Is this the right part number for an N/A Jap Import - 2pot front - 1 pot rear? wanted to make sure before I dismantal the brakes again? Obviously these are the front set. Link to comment Share on other sites More sharing options...
SILKYSMOOTH Posted February 8, 2008 Author Share Posted February 8, 2008 Anyone know? coz they look totally different to these below, and this is what I thought they would be. The new ones I have look like they need to placed into 2 pins or something that's maybe why there are 2 holes. Are these for UK spec Supra's? http://www.mkivsupra.net/vbb/showthread.php?t=120701&highlight=anti+squeal+shims Link to comment Share on other sites More sharing options...
foodfreak Posted February 8, 2008 Share Posted February 8, 2008 look like uk spec to me. Link to comment Share on other sites More sharing options...
Nic Posted February 9, 2008 Share Posted February 9, 2008 Sorry, I should have asked which brakes you had fitted first. Those are the shims for the larger 4 pot front brakes. The part number for the shims for the 2 pot fronts is 04945-14010 Link to comment Share on other sites More sharing options...
SILKYSMOOTH Posted February 9, 2008 Author Share Posted February 9, 2008 Sorry, I should have asked which brakes you had fitted first. Those are the shims for the larger 4 pot front brakes. The part number for the shims for the 2 pot fronts is 04945-14010 thats okay, I was also wrong to assume...not your fault. Thanks Nic Link to comment Share on other sites More sharing options...
SILKYSMOOTH Posted February 11, 2008 Author Share Posted February 11, 2008 £21 for these, how do they work that out? the bigger 4 pot (uk spec) ones I got were £11, these are double the price for the J spec NA Link to comment Share on other sites More sharing options...
razza Posted February 11, 2008 Share Posted February 11, 2008 stitch up because it's not a UK car, try getting it booked in for a service (although wouldn't recommend Toyota for this), and it'll be a no show probably.... Link to comment Share on other sites More sharing options...
SILKYSMOOTH Posted February 11, 2008 Author Share Posted February 11, 2008 stitch up because it's not a UK car, try getting it booked in for a service (although wouldn't recommend Toyota for this), and it'll be a no show probably.... Will be taking it in for a service very soon. Link to comment Share on other sites More sharing options...
JohnnyW Posted February 11, 2008 Share Posted February 11, 2008 £21 each or for the pair? I'm need to get these ordered shortly. Link to comment Share on other sites More sharing options...
Epic Posted February 11, 2008 Share Posted February 11, 2008 So from your local toyota dealer the UK set were £11? 04945-14110 Front Brake Shim Kit Link to comment Share on other sites More sharing options...
SILKYSMOOTH Posted February 11, 2008 Author Share Posted February 11, 2008 £21 each or for the pair? I'm need to get these ordered shortly. Front kit, so will be for the pair. J spec 2 pot front brake kit part no: 04945-14010 I hope, will update when I recieve them just to be sure. Link to comment Share on other sites More sharing options...
SILKYSMOOTH Posted February 11, 2008 Author Share Posted February 11, 2008 So from your local toyota dealer the UK set were £11? 04945-14110 Front Brake Shim Kit Yep...thats including the VAT. but for larger 4 pot I think, Pics of the parts above. Link to comment Share on other sites More sharing options...
Epic Posted February 11, 2008 Share Posted February 11, 2008 kool, ill get dressed n go order some then Link to comment Share on other sites More sharing options...
SILKYSMOOTH Posted February 13, 2008 Author Share Posted February 13, 2008 Received the new parts today and I can confirm that these are the right ones for the J spec N/A 2pot front brakes. Link to comment Share on other sites More sharing options...
Supra-Brett Posted February 13, 2008 Share Posted February 13, 2008 I have exactly the same squeeking at low speeds. Please let me know if it fixes the problem Link to comment Share on other sites More sharing options...
SILKYSMOOTH Posted February 14, 2008 Author Share Posted February 14, 2008 I have exactly the same squeeking at low speeds. Please let me know if it fixes the problem should have them fitted on Saturday so will let you know. Link to comment Share on other sites More sharing options...
SILKYSMOOTH Posted February 18, 2008 Author Share Posted February 18, 2008 Fitted the front shims on Saturday, but I still need to bleed the front brakes again, so I havn't driven it yet..Hope to later on today providing someone lends me one of their legs to press the brake pedal. Hopefully squealing will have gone. I will probably take the back wheels/brakes off too and give them a good grease too between the shims again just to be sure. Link to comment Share on other sites More sharing options...
DaveSupTT Posted February 18, 2008 Share Posted February 18, 2008 I have exactly the same squeeking at low speeds. Please let me know if it fixes the problem Link to comment Share on other sites More sharing options...
ShamelessTT Posted February 18, 2008 Share Posted February 18, 2008 Im pretty sure ive got all that fitted and mine still does it!! Everything to do with braking on my car is less than 8 months old.... Link to comment Share on other sites More sharing options...
SILKYSMOOTH Posted February 18, 2008 Author Share Posted February 18, 2008 Im pretty sure ive got all that fitted and mine still does it!! Everything to do with braking on my car is less than 8 months old.... Mine are less than 6 months old too..and it has improved since I changed the pads and discs, the fact that I did not have any anti squeal shims on the front makes me think....thats why!, it doesn't squeal much TBH only from time to time, I think they should be okay, especially when I grease the rear too. Link to comment Share on other sites More sharing options...
ShamelessTT Posted February 18, 2008 Share Posted February 18, 2008 Its time to time on mine 2, but when it does......boy does it make a noise!! Link to comment Share on other sites More sharing options...
SILKYSMOOTH Posted February 18, 2008 Author Share Posted February 18, 2008 Its time to time on mine 2, but when it does......boy does it make a noise!! Thats why I called the thread 'Annoying' - By the sounds of it, mine is not as bad as yours, but im sure if you just take all the brakes off and give'em a good clean and regrease it will be okay. Plus the bonus is...the car gets a thorough clean now and again. Link to comment Share on other sites More sharing options...
