Removing door graphics ...
MaRkYbOy72
doesnt look too bad on a silver car. my supra was covered in decals when i got it. i found that using a steam cleaner made getting them off very easily. if there was any sticky residue left on the paint. bug and tar remover, followed by a polish and wax cleared it all up a treat
Guest craig-mkiv
i've also got the same on mine :p
only mine is on the front wing's aswell ;)
if i wanted to remove them i would prob try heating it up with an hair-dryer :innocent:
I had a week long shop down my door, half of it weren't even on the car:blink: So i used a hairdryer to warm it up and take them off. there was some glue still on there but i bought some sticky stuff remover from halfords approx £3 then followed by a polish and you could never tell anything was once there:)
Your Supra is missing the front section of the optional 'Supra' vinyl so has presumably had a front end respray at some point.
As mentioned before, heat it with a high poweed hair dryer and they should peel off. Be very careful and take it slowly, it took about 2 hours to remove the ones from my car.
It will need a careful polish afterwards to remove the remaining glue residue.
