Guest Esmo Posted November 20, 2007 Share Posted November 20, 2007 Engine turns off when in heavy traffic??? Temperature guage does not rise! Link to comment Share on other sites More sharing options...
JustGav Posted November 20, 2007 Share Posted November 20, 2007 Need to give more information. Stab in the dark... dodgy alternator/battery not being able to run the electrics. Idle control valve not right (idling to low it stalls).. However need a lot more info before making a call. Link to comment Share on other sites More sharing options...
Ady Posted November 20, 2007 Share Posted November 20, 2007 sounds like you have some mega problems mate A calibra turbo i had used to do that - used to over heat, although the temp gaguge never rose, and the fan never kicked in. Turned out my head had cracked, and it set alight on me one day when the oil ran onto the red hot turbo Was a nice pre bonfire night i can tell ya! Link to comment Share on other sites More sharing options...
Guest Esmo Posted November 20, 2007 Share Posted November 20, 2007 Need to give more information. Stab in the dark... dodgy alternator/battery not being able to run the electrics. Idle control valve not right (idling to low it stalls).. However need a lot more info before making a call. Well the battery is brand new and i checked the alternator and thats fine.?? It only happens when im sitting in traffic for about 20mins and then the whole car shuts off, the stereo goes off for a split sec and then it comes back on. I then just slap in into neutral and she starts again no problem.? Link to comment Share on other sites More sharing options...
hoff Posted November 20, 2007 Share Posted November 20, 2007 Does your idle drop right down for a little while before cutting out? Link to comment Share on other sites More sharing options...
Guest Esmo Posted November 20, 2007 Share Posted November 20, 2007 Does your idle drop right down for a little while before cutting out? No, theres no way of tellin its going to happen. Link to comment Share on other sites More sharing options...
hoff Posted November 20, 2007 Share Posted November 20, 2007 Beats me, sorry. But i know very little technically though. Someone will be along im sure who can help you soon. Link to comment Share on other sites More sharing options...
JustGav Posted November 20, 2007 Share Posted November 20, 2007 Obvious one, is the battery cable tight? Link to comment Share on other sites More sharing options...
movistar Posted November 20, 2007 Share Posted November 20, 2007 Hows your clutch control;) Check your earths to the body as well as the batt terminals. Does the ignition still light up or is it as if someone has just disconnected the battery? Link to comment Share on other sites More sharing options...
Guest Esmo Posted November 20, 2007 Share Posted November 20, 2007 Hows your clutch control;) Check your earths to the body as well as the batt terminals. Does the ignition still light up or is it as if someone has just disconnected the battery? Cables are all gud, car just cuts out but all the electrics stayson inside. Its like the car is on a timer at low revs and switches off when idling too long. ??? Link to comment Share on other sites More sharing options...
miko_supra Posted November 20, 2007 Share Posted November 20, 2007 Obvious one, is the battery cable tight? lol one of mine was loose when i first got it. all the electrics died on the motorway at night. bit difficult trying to get over across 3 lanes to the hard sholder with no lights or indicators Link to comment Share on other sites More sharing options...
