paulrenn Posted June 25, 2002 Share Posted June 25, 2002 OK guys I want to know what is the maximum safe performance I can push the car to using stock turbos and fuel system. The car is using 550's and US (=UK I think) spec turbos. What is the maximum boost pressure that the ECU is programmed to support, if you use a boost controller to adjust the wastegate opening? ie, where does the fuelling map end, and fuel cut begin... Link to comment Share on other sites More sharing options...
GavinL Posted June 25, 2002 Share Posted June 25, 2002 Originally posted by paulrenn OK guys I want to know what is the maximum safe performance I can push the car to using stock turbos and fuel system. The car is using 550's and US (=UK I think) spec turbos. What is the maximum boost pressure that the ECU is programmed to support, if you use a boost controller to adjust the wastegate opening? ie, where does the fuelling map end, and fuel cut begin... I understand that the US/UK spec MAF works too 18psi/1.2bar approx. 18psi is a reasonable amount of boost for a BPU car. Link to comment Share on other sites More sharing options...
Syed Shah Posted June 25, 2002 Share Posted June 25, 2002 To answer your other question, fuel-cut is approx 15psi, so to run 18psi, you will need a FCD, there cost about 100quid, and I think Pete Betts sells them. Link to comment Share on other sites More sharing options...
Terminator Posted June 25, 2002 Share Posted June 25, 2002 Get you FCD from TRL Performance about £60 + post. Link to comment Share on other sites More sharing options...
THOR Racing Posted June 26, 2002 Share Posted June 26, 2002 Max recommended boost on stock system is 18psi (but maybe reduce this is really hot weather or get water injection or intercooler fitted) To get to 18psi you'll need some form of boost controller, manual or electronic and a fuel cut controller to get past the ECU safety mechanism at 15psi. For fuel cuts see TRL VFCC Regards Pete Link to comment Share on other sites More sharing options...
paulrenn Posted June 26, 2002 Author Share Posted June 26, 2002 Hi Pete Thanks for the reply. I'm definitely interested in the VFCC. From your experience, have you noticed differences in the ECU pinouts between the various MKIV models? Mine is a '97 and US spec, but the connectors are probably the same. Maybe time to hunt on mkiv.com for any wiring diagrams... Link to comment Share on other sites More sharing options...
THOR Racing Posted June 27, 2002 Share Posted June 27, 2002 I've got ECU pinouts of most variants of cars anyway. Bu they are generally the same for import,export markets. Colours may differ but pinouts stay the same. They also change on a year basis. Is the 97 a facelift model? Pete Link to comment Share on other sites More sharing options...
paulrenn Posted June 27, 2002 Author Share Posted June 27, 2002 Pete, you have mail Link to comment Share on other sites More sharing options...
