Toyota EPC probems...
Sean1933
I downloaded the toyota EPC last week from some torrent website. Basically i have 2 problems when getting it to work.
*Firstly, when running it in my normal resolution of 1024x768 (im on a 32" TFT) i can only see half the program and it wont resize :( . I have to run it in a high resolution like 1600 x 1024 or something like that. Any ideas?
*Secondly, When trying to look stuff up it says 'Execute the setup', help says this means i need to run the CD setup. When i run the CD setup to be honest i dont really know what to do. All the program+reference files are on the C: drive as per the brief instructions that came with it...
HELP!
  • 2 weeks later...
right...i got it working but i cant get the resolution to change...therefore the only way i can view the whole window/program is by running windows in a stupid resolution of like 1600x1024 meaning i cant rad any of it!
That's normal, it will only work in a small window
cd set up >
tick "Japanese area version" And if you have it "european version"
Click Add
If you have the data on cd's clcik a1 cd and a2 cd. then click ok
if you have the data on hard disk click a1 and a2 cd but then click the hard disk tab (the cd part will change to hard disk) click ok.
Then execute. you will be prompted for the disks insert them and your done.
Check it has worked by going to part no translation and searching for Sup
