Sean1933 Posted November 7, 2007 Share Posted November 7, 2007 I downloaded the toyota EPC last week from some torrent website. Basically i have 2 problems when getting it to work. *Firstly, when running it in my normal resolution of 1024x768 (im on a 32" TFT) i can only see half the program and it wont resize . I have to run it in a high resolution like 1600 x 1024 or something like that. Any ideas? *Secondly, When trying to look stuff up it says 'Execute the setup', help says this means i need to run the CD setup. When i run the CD setup to be honest i dont really know what to do. All the program+reference files are on the C: drive as per the brief instructions that came with it... HELP! Link to comment Share on other sites More sharing options...
Sean1933 Posted November 18, 2007 Author Share Posted November 18, 2007 Help! I downloaded Nics version to see if that works but its exactly the same as mine, therefore same problems . Trying to run it on Win XP. Link to comment Share on other sites More sharing options...
Sean1933 Posted November 18, 2007 Author Share Posted November 18, 2007 right...i got it working but i cant get the resolution to change...therefore the only way i can view the whole window/program is by running windows in a stupid resolution of like 1600x1024 meaning i cant rad any of it! Link to comment Share on other sites More sharing options...
RedM Posted November 18, 2007 Share Posted November 18, 2007 Can you do step-by-step on how you got it working? I have the same trouble but couldn't work out the 'execute' bit. Link to comment Share on other sites More sharing options...
Nic Posted November 18, 2007 Share Posted November 18, 2007 right...i got it working but i cant get the resolution to change...therefore the only way i can view the whole window/program is by running windows in a stupid resolution of like 1600x1024 meaning i cant rad any of it! That's normal, it will only work in a small window Link to comment Share on other sites More sharing options...
Nic Posted November 18, 2007 Share Posted November 18, 2007 Can you do step-by-step on how you got it working? I have the same trouble but couldn't work out the 'execute' bit. Martin drop me a pm if you want a link to my EPC file, it come with installation instructions Link to comment Share on other sites More sharing options...
colsoop Posted November 18, 2007 Share Posted November 18, 2007 cd set up > tick "Japanese area version" And if you have it "european version" Click Add If you have the data on cd's clcik a1 cd and a2 cd. then click ok if you have the data on hard disk click a1 and a2 cd but then click the hard disk tab (the cd part will change to hard disk) click ok. Then execute. you will be prompted for the disks insert them and your done. Check it has worked by going to part no translation and searching for Sup Link to comment Share on other sites More sharing options...
