ben.supra Posted September 8, 2007 Share Posted September 8, 2007 i took supra to BP with on few quid left in tank..i put only £10 in {not relising it was deisel}OK ...i left BP to put car back in garage half mile uproad car started to run "crap" AND STARTED TO STOP RUNNING.i managed to get car into my garage then that was it will not start!!!!then relised i must have put deisel in tank.. in garage i drianed out £10 worth fuel with 1/4 clear hose line now theres not much in tank now do i leave it for maechanic to tow it away or SHALL I just fill tank up with super unleaded and try start car running it through WHAT SHALL I DO NEXT HELP Link to comment Share on other sites More sharing options...
DannoSupra Posted September 8, 2007 Share Posted September 8, 2007 Just fill it up dude, and let it flush through! Â Different story if it were petrol in a diesel car Link to comment Share on other sites More sharing options...
jamesmark Posted September 8, 2007 Share Posted September 8, 2007 This always amazes me. Link to comment Share on other sites More sharing options...
ben.supra Posted September 8, 2007 Author Share Posted September 8, 2007 This always amazes me.  it was an accident...but i do drive company deisel car all the time aswell..i had lot on my mined when i did it i just didnt think.."brat i am i know" u guys reckon i should just fill tank with fuel and try strating it Link to comment Share on other sites More sharing options...
Jake Posted September 8, 2007 Share Posted September 8, 2007 Just fill it up dude, and let it flush through! I wouldn't do that. Â I'd drain the tank Ben. Either from the fuel filter connection or by taking the cover off the tank and lifting out the pump hanger and then syphoning the fuel out. Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted September 8, 2007 Share Posted September 8, 2007 Sonds like he as already drained it and is just worried. Link to comment Share on other sites More sharing options...
ben.supra Posted September 8, 2007 Author Share Posted September 8, 2007 I wouldn't do that.  I'd drain the tank Ben. Either from the fuel filter connection or by taking the cover off the tank and lifting out the pump hanger and then syphoning the fuel out.   ok thanks, i let mechanic low loader car away and have it done right then...... Link to comment Share on other sites More sharing options...
Homer Posted September 8, 2007 Share Posted September 8, 2007 Well, thats 3 of us that have done that at BP now  As Jake says, you really need to fush it out, then fill the tank completely on the next refil (it'll help dilute any deisel thats left). Link to comment Share on other sites More sharing options...
DannoSupra Posted September 8, 2007 Share Posted September 8, 2007 I wouldn't do that.  I'd drain the tank Ben. Either from the fuel filter connection or by taking the cover off the tank and lifting out the pump hanger and then syphoning the fuel out. Why not? its not like its a bloody high tech diesel engine is it? It'll be fine, just have to put up with it for a bit, not driving it hard. If he's drained the tank allready then there's no problem Link to comment Share on other sites More sharing options...
Jake Posted September 8, 2007 Share Posted September 8, 2007 Well besides the possible damage it could cause, 'cos it'll smoke like the ace of spades. Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted September 8, 2007 Share Posted September 8, 2007 Why not? its not like its a bloody high tech diesel engine is it? It'll be fine, just have to put up with it for a bit, not driving it hard. If he's drained the tank allready then there's no problem Id agree but he MUST fill it right up and drive it gently, i.e off boost Link to comment Share on other sites More sharing options...
ben.supra Posted September 8, 2007 Author Share Posted September 8, 2007 well mechanic siad my oxygen sensers and plugs could be coated up and he said i could damage pistons????yeah right..i didnt really run car much on diesel tank sounds really empty now so i,m 50/50 on this now mechanic or just fill tank up and hope for the best it's non turbo supra Link to comment Share on other sites More sharing options...
Jake Posted September 8, 2007 Share Posted September 8, 2007 Why wouldn't you just drain the tank though? It's a simple enough job and avoids the possible risk and the having to drive Miss Daisy for next 300 miles. Link to comment Share on other sites More sharing options...
Homer Posted September 8, 2007 Share Posted September 8, 2007 I can tell you for sure that the deisel fumes will kill any O2 sensor in no time, after about 20 minutes of idle it killed both the stock O2 and wideband sensors on my car. Link to comment Share on other sites More sharing options...
JustGav Posted September 8, 2007 Share Posted September 8, 2007 This would be my take on it... While the car would run initially would the diesel act well like diesel and detonation under cylinder pressures, and start blowing holes in things eventually if there is enough of it in the system? Also being thicker would it stand a good chance of blocking the injectors? Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted September 8, 2007 Share Posted September 8, 2007 Ahh NA, Well I once put only £5 of diesel in my NA when empty (I also got caught out) but then I stayed at the petrol station and whacked in £50 of petrol straight on top. Which would of mixed it well before entering the engine. May get lucky on the 02 Sensors. Link to comment Share on other sites More sharing options...
