J-Spec Pads?
Guest scw02102
Originally posted by scw02102
Will the Uk spec Pads fit J spec brakes?
If not where can i get some J-spec pads from?
How much do these normally cost??
Thanks
No they don't.
Well we recommend the Endless SSS Pads for £125 a set. These are uprated items and much better than the stock Jspec versions.
Regards,
Gaz.
Getting brand new j-spec discs, braided lines, 5.1 fluid and CW fast road pads fitted tomorrow (fronts and rears).
Wonder how this compares to: 11 yr old knackered discs, 'green/red stuff' pads (i.e. fecking hopeless), cooked fluid and split 11 yr old brakes lines...
Will let you know the results :D
