Mas Posted August 21, 2007 Share Posted August 21, 2007 Might you guys covered this before, but I need to get this dorted asap as I nearly smashed into some idiots reversing into me and I couldnt even sound my horn as it for some reasons stoped working! I was looking into the fuse box and need to check the horn thingy is working or not, but I cant get it out! Is this the right bit that I have to check ? how to check ? any other ideas why the horn stopped working suddenly? its nearly new and was working fine for the past few months! Thanks for any help in advance Link to comment Share on other sites More sharing options...
JODY T Posted August 21, 2007 Share Posted August 21, 2007 The relay for the horn is the smaller grey one to the right of the one you highlighted. Question........ Do you have a standard steering wheel? Have you removed the cover so you can see the horn wires? You should be able to earth the horn to get it to sound... You can see if its the switching or an actual power supply problem... Ive seen many standard steering wheel horn problems... (to remove the cover of the wheel, if you turn it upside down you will find a screw holding it on... Most people dont see this and just pull... The problem is this screw acts as the earth if the thread has snapped off when you press the horn it wont earth, thus not work) has anything else stopped working? Im guessing you have checked the fuses? Link to comment Share on other sites More sharing options...
MarkR Posted August 21, 2007 Share Posted August 21, 2007 Viagra? Link to comment Share on other sites More sharing options...
Golddigga Posted August 21, 2007 Share Posted August 21, 2007 Look at Jody T's avatar....should solve the problem Link to comment Share on other sites More sharing options...
MarkR Posted August 21, 2007 Share Posted August 21, 2007 Link to comment Share on other sites More sharing options...
Mas Posted August 21, 2007 Author Share Posted August 21, 2007 The relay for the horn is the smaller grey one to the right of the one you highlighted. Question........ Do you have a standard steering wheel? Have you removed the cover so you can see the horn wires? You should be able to earth the horn to get it to sound... You can see if its the switching or an actual power supply problem... Ive seen many standard steering wheel horn problems... (to remove the cover of the wheel, if you turn it upside down you will find a screw holding it on... Most people dont see this and just pull... The problem is this screw acts as the earth if the thread has snapped off when you press the horn it wont earth, thus not work) has anything else stopped working? Im guessing you have checked the fuses? No mate I ve got a momo steering wheel in the car and the fuses were all ok as I checked them before getting to the grey relay which I couldnt remove or do anything to it! Link to comment Share on other sites More sharing options...
JODY T Posted August 21, 2007 Share Posted August 21, 2007 take off the horn button, remove the black wire behind it an earth it.. does it go off? unfortunatly its a process of elimiation.. have you checked both fuse boxes? check for power at the wheel, connect the horn itself to the batt bypassing the car loom.. check for power at the fuse/relay... if you do all that you should trace the problem.. Link to comment Share on other sites More sharing options...
RobSheffield Posted August 21, 2007 Share Posted August 21, 2007 Viagra? Look at Jody T's avatar....should solve the problem Lads, this is Tech, and in tech any offtopic banter is very much frowned on Link to comment Share on other sites More sharing options...
Golddigga Posted August 22, 2007 Share Posted August 22, 2007 At least were not making snide comments or taking the pi** which seems to happen alot but point taken. Link to comment Share on other sites More sharing options...
Mas Posted August 22, 2007 Author Share Posted August 22, 2007 take off the horn button, remove the black wire behind it an earth it.. does it go off? unfortunatly its a process of elimiation.. have you checked both fuse boxes? check for power at the wheel, connect the horn itself to the batt bypassing the car loom.. check for power at the fuse/relay... if you do all that you should trace the problem.. Nice one mate, will give it a try and do the above one by one and hopefully get that sorted. Cheers Link to comment Share on other sites More sharing options...
MarkR Posted August 22, 2007 Share Posted August 22, 2007 Sorry Link to comment Share on other sites More sharing options...
TNT Posted October 15, 2007 Share Posted October 15, 2007 Nice one mate, will give it a try and do the above one by one and hopefully get that sorted. Cheers Mas, Did you have any joy, mine has just given up, sounds like a similar problem following handing the car over for a refit. Link to comment Share on other sites More sharing options...
