Ian C Posted August 13, 2007 Share Posted August 13, 2007 IMO the datalogging on the EMU isn't all that, and as i said the logged AFR plot is only as good as the users ability to get the inputs and output spot on, and so far i still can't get the EMU AFR plot to match the Innovate (which may be my fault, but i have spent a lot of time trying to get it right) and i would rather trust the Innovate;) Plus the EMU certainly doesn't come close to the logging ability's of the Innovate, and its quite easy to create a log that corresponds to the EMU maps;) A little extra work is needed for the datalogging but mine end up like this with one click of a macro button Works OK for me. The MAP2 ECU and the EMU are, as Brian says, horses for courses. Can't argue with his results on one! -Ian Link to comment Share on other sites More sharing options...
tucky40 Posted August 13, 2007 Share Posted August 13, 2007 Ian C, id like to have a chat with you about the emu etc, i did speak to Nic about prices and he said to contact you regarding mapping. Could you possibly pm me your number and ill give you a shout over the next week. Thanks, ben. Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 13, 2007 Share Posted August 13, 2007 A little extra work is needed for the datalogging but mine end up like this with one click of a macro button Works OK for me. The MAP2 ECU and the EMU are, as Brian says, horses for courses. Can't argue with his results on one! -Ian I use this method with EMU and Logworks, can get virtually identical log verses load sites. Link to comment Share on other sites More sharing options...
Ian C Posted August 13, 2007 Share Posted August 13, 2007 I see how that works, that's quite clever, but it doesn't account for accel pumps or liftoff overfuelling surely? Also, I have to say, what is going on with your duty cycle adjustments dude, they are all over the shop -Ian Link to comment Share on other sites More sharing options...
tDR Posted August 13, 2007 Share Posted August 13, 2007 For reference, a log from my MAP2 with AFR included using input coming from Innovate output: Link to comment Share on other sites More sharing options...
Ian C Posted August 13, 2007 Share Posted August 13, 2007 I find it almost impossible to map from a graph Give me a spreadsheet any day -Ian Link to comment Share on other sites More sharing options...
tDR Posted August 13, 2007 Share Posted August 13, 2007 Your spreadsheet values are in the little boxes at the bottom showing values for the current position in the log - I like it like that, easy to see what's happening I reckon - just depends which way your brain works as to which you prefer! The log files are stored in comma seperated value format so very easy to pull them into an excel spreadsheet if that's what floats yer boat Cheers, Brian. Link to comment Share on other sites More sharing options...
stupra Posted August 13, 2007 Author Share Posted August 13, 2007 Wow, this has gone off on a tangent . None of the tech stuff make's any sense to me, but I was told good thing's about the EMU which is why I went for it. I also went on the fact that if an EMB is capable of running a single, the EMU will be more than up to the job of running my BPU plus cam's an injector's set up. Having Ian quite near and willing to map it for me is a bonus . Not saying the MAP2 wouldn't be able to do just as good a job though. Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 13, 2007 Share Posted August 13, 2007 I see how that works, that's quite clever, but it doesn't account for accel pumps or liftoff overfuelling surely? Also, I have to say, what is going on with your duty cycle adjustments dude, they are all over the shop -Ian You can account for that to a degree by checking max and min and the number of data points. Those two examples may not have been directly connected, ( just an example) but they do tend to look like that, don't forget that i don't use the airflow map like you Ian, + it works for me:) I also can't deal with mapping from graphs;) Link to comment Share on other sites More sharing options...
tucky40 Posted August 14, 2007 Share Posted August 14, 2007 So can a fuel pressure regulator be used instead of getting a set of injectors?? im thinking an fpr is the cheaper option, but is it just as effective? .........for example if more fuel was needed after upgrading the cams Link to comment Share on other sites More sharing options...
tDR Posted August 14, 2007 Share Posted August 14, 2007 It's a fudge.... best with correctly sized injectors for reliability. Cheers, Brian. Link to comment Share on other sites More sharing options...
Ian C Posted August 15, 2007 Share Posted August 15, 2007 So can a fuel pressure regulator be used instead of getting a set of injectors?? im thinking an fpr is the cheaper option, but is it just as effective? .........for example if more fuel was needed after upgrading the cams It's not really effective. If you up the overall fuel pressure to compensate for 6000-6800rpm on full boost, you will run richer across the whole range, from idle to cruise to full boost under 6krpm. Closed loop will pull some of it out, but each change in throttle position will take longer to recover back to stoich. Your fuel usage will go up noticeably, and you can sap power when on boost as closed loop is switched off and it already runs really rather rich when BPUd with no fuelling adjustment. -Ian Link to comment Share on other sites More sharing options...
tucky40 Posted August 15, 2007 Share Posted August 15, 2007 thanks guys Ian could you send me a pm with your contact details so i can talk to you about getting the emu etc. Ben. Link to comment Share on other sites More sharing options...
