Guest shifty Posted August 1, 2007 Share Posted August 1, 2007 Hi Everyone, Im new here, recently sold my MR2 turbo so upgrade to a Supra (which i hope to get in the very near future ). I was just wondering, does a Supra fit in a normal size single Garage? Sorry if this Question has been asked before, I did try searching first. cheers, Karl Quote Link to comment Share on other sites More sharing options...
Ewen Posted August 1, 2007 Share Posted August 1, 2007 Do you have an Aerotop ? Quote Link to comment Share on other sites More sharing options...
Guest shifty Posted August 1, 2007 Share Posted August 1, 2007 I dont think it will be, but i could always get a winch Quote Link to comment Share on other sites More sharing options...
Guest Chumpalot Posted August 1, 2007 Share Posted August 1, 2007 I reckon it would but it would be a tight squeeze. Would help if you had folding wing mirrors as well Quote Link to comment Share on other sites More sharing options...
Ewen Posted August 1, 2007 Share Posted August 1, 2007 Standard length / width, no bodykit.... Length 4,520mm Width 1,810mm I can get it into my garage, but I then have to climb out through the window:) Quote Link to comment Share on other sites More sharing options...
Daston Posted August 1, 2007 Share Posted August 1, 2007 My garage is a small one meeting the basic requirments I have around 6" clearence either side of the doors and around 10" clearence when in the garage with around 12" clear at the front. Quote Link to comment Share on other sites More sharing options...
Daston Posted August 1, 2007 Share Posted August 1, 2007 another tip is to put the window down get out and the put it up. The windows curve inwards same as the MR2's Quote Link to comment Share on other sites More sharing options...
Guest shifty Posted August 1, 2007 Share Posted August 1, 2007 Cheers guys, its not the length im worried about. Id probably have to get out through the window too or push/pull it in/out. Quote Link to comment Share on other sites More sharing options...
jevansio Posted August 1, 2007 Share Posted August 1, 2007 Mine goes in width ways but not length ways (ooo err misus) Quote Link to comment Share on other sites More sharing options...
Guest Chumpalot Posted August 1, 2007 Share Posted August 1, 2007 stick some carpet to the garage wall so you don't damage your doors Quote Link to comment Share on other sites More sharing options...
Guest shifty Posted August 1, 2007 Share Posted August 1, 2007 another tip is to put the window down get out and the put it up. The windows curve inwards same as the MR2's I had closure on the alarm with my MR2 so that was easy to get in and out of. But i know what you are talking about. The worse part by my rekoning is getting it through the door, i worked out I'd only have about 2-3inchs either side but once past the door the garage widens alot. Quote Link to comment Share on other sites More sharing options...
Guest shifty Posted August 1, 2007 Share Posted August 1, 2007 stick some carpet to the garage wall so you don't damage your doors Way ahead of you there, the garage is already completly carpeted. I spent alot of time in there beofre with my MR2 cleaning It was an obsession to keep it clean. Quote Link to comment Share on other sites More sharing options...
livvy Posted August 1, 2007 Share Posted August 1, 2007 I had closure on the alarm with my MR2 so that was easy to get in and out of. But i know what you are talking about. The worse part by my rekoning is getting it through the door, i worked out I'd only have about 2-3inchs either side but once past the door the garage widens alot. Do you have an "up and over" garage door? I have a piece of string with a weight on the end tied to the bottom corner of the door on the "near-side" (so when the door's up its like a plumb line)that way you know exactly where the side of the car is in relation to the door frame... Quote Link to comment Share on other sites More sharing options...
Guest shifty Posted August 1, 2007 Share Posted August 1, 2007 Yes it is an up and over door. The weight is quite a good idea but dont you worry about it hitting the car? Quote Link to comment Share on other sites More sharing options...
Daston Posted August 1, 2007 Share Posted August 1, 2007 use a tennis ball. With my mirrors out I have around 1/2" each side, your garage sounds a lot like mine so you should have no problems at all. Remember that a car will never be wider than its wingmirrors.....well a stock on wont be anyway Quote Link to comment Share on other sites More sharing options...
livvy Posted August 1, 2007 Share Posted August 1, 2007 Yes it is an up and over door. The weight is quite a good idea but dont you worry about it hitting the car? Forgot to mention - its a wheel nut wrapped in bubble wrap:) Tennis ball works just as well though!! Quote Link to comment Share on other sites More sharing options...
Guest shifty Posted August 1, 2007 Share Posted August 1, 2007 Well cheers for the help and ideas, i was paranoid that when i get the car home it wouldnt fit. I obviously wont be able to clean it in there like i could my MR. Quote Link to comment Share on other sites More sharing options...
Daston Posted August 1, 2007 Share Posted August 1, 2007 Crap man if you could clean your MR2 in there you got no problems! When I had my MR2 I could just about walk down the side of the car but not enough room to clean it! Quote Link to comment Share on other sites More sharing options...
Guest shifty Posted August 1, 2007 Share Posted August 1, 2007 when i had it in the garage i could easily walk down one side but would have to side step on the other side. here is pic so you can see the scale http://img77.imageshack.us/img77/25/mr2garagedp9.jpg Well now i know a soop will fit, i hope a nice one will come up for me to buy Quote Link to comment Share on other sites More sharing options...
Daston Posted August 1, 2007 Share Posted August 1, 2007 hehe mine will be up as soon as I get my wings sprayed Quote Link to comment Share on other sites More sharing options...
ivan Posted August 1, 2007 Share Posted August 1, 2007 when i had it in the garage i could easily walk down one side but would have to side step on the other side. here is pic so you can see the scale http://img77.imageshack.us/img77/25/mr2garagedp9.jpg Well now i know a soop will fit, i hope a nice one will come up for me to buy LOL - that's wider than my whole driveway. At the bottom of it I've got an old 1920's garage built for a Model T and haven't got a chance of getting even the nose in. Quote Link to comment Share on other sites More sharing options...
dr_blackman Posted August 1, 2007 Share Posted August 1, 2007 I can get mine in the garage but i struggle to get out hence why i dont bother with the garage, too much hazzle, only pop it in there when i go away etc Quote Link to comment Share on other sites More sharing options...
