UK Supra TT Posted July 29, 2007 Share Posted July 29, 2007 Hi guys, I've just come to the end of my single turbo conversion on my mkiv UK supra, the inlet to my turbo is 4" and the standard AFM is 3" ish, I want to run a MAP sensor instead of the AFM, it would also make evreything alot neeter, anyone got any idea how I can do this? I was thinking about trying a jap spec ECU on my UK car, is this possible? I was looking at a HKS VPC, they don't seem to be readily available though. Another thing I was thinking of mapping my E-Manage to a MAP sensor instead, I can't think of any reason why it wouldn't work but any anyone set me straight? Cheers, Jon Link to comment Share on other sites More sharing options...
Wez Posted July 29, 2007 Share Posted July 29, 2007 AEM ECU can use either but most convert to MAP only use. It might be possible to do something with an EMU as well, Ian C would be the man to ask. Link to comment Share on other sites More sharing options...
UK Supra TT Posted July 29, 2007 Author Share Posted July 29, 2007 Hi wez thanks for the reply, yeah i know there's several stand alone ECU's out there that will do it but I was wondering if i could do it with my standard ECU and an E-Manage or if there was another piggy back device i could get to do it, like the MAP-ECU, available at powerhouse racing Cheers Link to comment Share on other sites More sharing options...
tDR Posted July 29, 2007 Share Posted July 29, 2007 MAP2 ECU will do the trick - speak to dusty@mvp Link to comment Share on other sites More sharing options...
Homer Posted July 29, 2007 Share Posted July 29, 2007 You can't do it with the standard ECU still in place. Best off going for a standalone if you want to be rid of it for good. I know someone who might be offering a deal on the Link ECU shortly Link to comment Share on other sites More sharing options...
Guest bass-t Posted July 30, 2007 Share Posted July 30, 2007 You can't do it with the standard ECU still in place. You can using a MAP-ECU or MAP-ECU2 Link to comment Share on other sites More sharing options...
UK Supra TT Posted July 31, 2007 Author Share Posted July 31, 2007 cool cheers guys, Homer, will the link ECU work on an auto, as far as I understand it alot of the aftermarket ECU's don't work on auto's Link to comment Share on other sites More sharing options...
