HKS Turbo onto Boost logic Single Kit
Pig
What challenges am i going to encounter? Has anyone done this before?
Will the manifold be ok (boost logic one) and what about the downpipe?
Dont want to end up buying the whole single kit
Guest Terry S
Well it's a T4 flange, so no issue, also as long as it's a 2.5" V band outlet on the exhaust housing that will be OK. You need to think about your IC pipe routing though as it won't have the usual elbow on the comp housing to take the IC pipe through the inner wing.
Guest Terry S
FWIW Jon, why don't you get a BL67 DBB, it's virtually identical, and bolts straight up, oh and it's cheaper too!
