i've got a nubbin! any clues?
Blackie
Assuming, Lewis, that you didn't have a clue what it was, what search terms would you use?
Dome on dash?!
That's what I would type..... I do (unfortunately) agree that it may be a chicken prior to an egg. My smiley still stands though!! :D
i noticed this the other day. so i guess its tied into the climate control?
Whenever i turn mine onto "auto" the fan goes mental, and my face goes freezing, my hair goes all over the place, and i have to turn the radio up.
Would have been 10 seconds if you had searched :p
That's easy to say and I've read the same 100 times. But what what would you search for in this instance. Sometimes it's very hard to know what to type in that little box.:)
that explains that too, also i could only think of calling it a nubbin and dome on the dash never entered my head
just found this in a thread lewis gave us:
According to some website I found, there's a moisture sensor and a solar sensor. In conjunction with each other, the relative humidity on the windscreen is calculated so the air-con operates to reduce fogging.
From looking at what the climate control does in the supra, it appears to be able to change the fan speed and change whether the air is on outside or recirculate.
clever init!!
Too slow tony - to get beaten by martin, now THAT'S an achievement :D
