Ulrik Posted July 17, 2007 Share Posted July 17, 2007 Im having problems with my HKS EVC EZII with EVC 5 Screen Boost Controller. The powerlight keeps blinking Red, and i cant find the manuel to either of them. I need both the EZII and EVC 5(4?) Manuel. Can somone post a link or show me where to download it ? Or if somone knows the problem when the power light button keep blinking red. Anyone know ? Need quick awnsers, we are in the garage trying to hook up some parts. Thanks alot guys // André from Sweden Link to comment Share on other sites More sharing options...
Guest whatthe Posted July 17, 2007 Share Posted July 17, 2007 Im having problems with my HKS EVC EZII with EVC 5 Screen Boost Controller. The powerlight keeps blinking Red, and i cant find the manuel to either of them. I need both the EZII and EVC 5(4?) Manuel. Can somone post a link or show me where to download it ? Or if somone knows the problem when the power light button keep blinking red. Anyone know ? Need quick awnsers, we are in the garage trying to hook up some parts. Thanks alot guys // André from Sweden Mine will do that if you turn the boost setting knob while not in that mode. You have to turn the setting back to what it was before the knob was bumped and then make adjustments. Link to comment Share on other sites More sharing options...
Ulrik Posted July 17, 2007 Author Share Posted July 17, 2007 Mine will do that if you turn the boost setting knob while not in that mode. You have to turn the setting back to what it was before the knob was bumped and then make adjustments. Not the boost buttons A and B, im talking about the Power Light button on the left....the one with a circle... It keeps blinking red.... Anyone knows ? Somone thing with the ground or the + connection ? // André Link to comment Share on other sites More sharing options...
bromy Posted July 17, 2007 Share Posted July 17, 2007 Are you internal or external wastegate? Link to comment Share on other sites More sharing options...
Ulrik Posted July 17, 2007 Author Share Posted July 17, 2007 Are you internal or external wastegate? External greddy type r wastegate.. Singel Turbo... But the button on the backside is right...for the external.. Anything elles? // André Link to comment Share on other sites More sharing options...
Guest whatthe Posted July 17, 2007 Share Posted July 17, 2007 Is this a new install? This is on the little controller and it is not on the digital display? Nothing is beeping? try switching it back to sw with power on and see what happens. If it goes off, switch back to the mode you need with the power off. Link to comment Share on other sites More sharing options...
bromy Posted July 17, 2007 Share Posted July 17, 2007 From the flashing light it sounds like it is not set up correctly, there is a switch on the back of the control box to select the type of wastegate you are using internal or external this needs to be set to external (PO setting) mine was set to PO for my external gate but still had the flashy light and no boost control...... Turn the ingition ON but dont start the car If the controller turns on during the ignition then power it off with the PWR button on the display. Then put the switch back to SW mode (internal gate) PWR it on PWR it off then put the swtich to PO mode (external gate) Then PWR it on This should get rid of the flashing red power button Link to comment Share on other sites More sharing options...
Nic Posted July 17, 2007 Share Posted July 17, 2007 I have the EVC V instructions on my public folder here http://homepage.mac.com/importpimp/ Link to comment Share on other sites More sharing options...
Ulrik Posted July 17, 2007 Author Share Posted July 17, 2007 From the flashing light it sounds like it is not set up correctly, there is a switch on the back of the control box to select the type of wastegate you are using internal or external this needs to be set to external (PO setting) mine was set to PO for my external gate but still had the flashy light and no boost control...... Turn the ingition ON but dont start the car If the controller turns on during the ignition then power it off with the PWR button on the display. Then put the switch back to SW mode (internal gate) PWR it on PWR it off then put the swtich to PO mode (external gate) Then PWR it on This should get rid of the flashing red power button This sounds about right i guess, i will try this tomorow. Thanks alot mate // André Link to comment Share on other sites More sharing options...
Ulrik Posted July 18, 2007 Author Share Posted July 18, 2007 Thanks alot bromy Problem solved.... // André Link to comment Share on other sites More sharing options...
