BigRoy Posted October 16, 2004 Share Posted October 16, 2004 OK so I'm blonde! I just rembered that I never pulled my trac fuse, I use to just use the button! Having done it today, I'm impressed with the improvement:thumbs: Question is, I dont notice any difference in harshness of changes on the auto? Is there a now a definite theory on this one? And can you stop the OD light flashing? Link to comment Share on other sites More sharing options...
veilsideTT Posted October 16, 2004 Share Posted October 16, 2004 I was always was led to beleive that the Auto ECU retards the timing on gear changes so to protect the auto box from taking too much power as it engages its next gear??? I never understand how the pulling the TRAC fuse prevents this from happening? Does the ECU take a signal from the Traction Controll system to tell it that the car is about to change gear thus causing the ECU to retard the timing?? I can only imagine that without that signal from the traction controll system (with fuse pulled), the ECU never retards on gear change? Awaits to be corrected and flamed!!! Scott Link to comment Share on other sites More sharing options...
Syed Shah Posted October 16, 2004 Share Posted October 16, 2004 Apparently, on gear changes in an auto, the TRC butterfly in the TB closes momentarily to make it easier on the gearbox. Pulling the trac fuse will stop this, which is said to lead to a reduced gearbox life, but how reduced nobody is sure. FWIW, Terminator has had his TRC butterfly removed for a few years now on an auto, and has not had any problems, so not something to have sleepless nights over. Link to comment Share on other sites More sharing options...
BigRoy Posted October 16, 2004 Author Share Posted October 16, 2004 Strange. Performance wise, first pulls much much stronger and second gears comes on alot stonger but no difference in the actual change. In actual fact the change appears to be smoother? Anyone got a fix for the OD light flash? Link to comment Share on other sites More sharing options...
geoffvalenti Posted October 16, 2004 Share Posted October 16, 2004 Originally posted by BigRoy Anyone got a fix for the OD light flash? What, apart from removing the bulb Link to comment Share on other sites More sharing options...
geoffvalenti Posted October 16, 2004 Share Posted October 16, 2004 Shame you can't do this with the VVTi tiptronic models. Pulling the trac fuse results in increased idle, elimination of anti squat (makes the initial engagement of gears from neutral smoother) and greatly reduced sensitivity on the fly by wire throttle. So much so that it wont start to increase revs until 1/2 way down, a bit like the dreaded snow mode Probably the only way to remove it is to remove the butterfly, but sometimes that ultra quick manual change sound, you get when accellerating hard is nice If I could find a way of stopping it messing with the butterfly at WOT I'd put up with that. Any takers? Link to comment Share on other sites More sharing options...
mr keef Posted October 16, 2004 Share Posted October 16, 2004 is there anything to be gained by doing this on a 6 speed manual tt? Link to comment Share on other sites More sharing options...
LeeT Posted October 16, 2004 Share Posted October 16, 2004 Originally posted by BigRoy Anyone got a fix for the OD light flash? Roy, Matt Harwood does a kit for a £5 to stop the light flashing through Vortex:thumbs: Link to comment Share on other sites More sharing options...
Scooter Posted October 16, 2004 Share Posted October 16, 2004 Originally posted by mr keef is there anything to be gained by doing this on a 6 speed manual tt? depends if you drive with the TC generally off or on. I used to just pull mine to save pressing the button to turn it off every time. No performance advantage, but no chance of any damage to anything either..... Link to comment Share on other sites More sharing options...
BigRoy Posted October 16, 2004 Author Share Posted October 16, 2004 Originally posted by Scooter depends if you drive with the TC generally off or on. I used to just pull mine to save pressing the button to turn it off every time. No performance advantage, but no chance of any damage to anything either..... I thought it still retarded the timing using the button? Makes a noticable difference to mine. I knows its an auto but as said the changes up dont feel harsher but it pulls very differently. Link to comment Share on other sites More sharing options...
mr keef Posted October 16, 2004 Share Posted October 16, 2004 so am i right in saying it just gives the driver a bit more controll over the car?i always drive with it on,cant say i'v really noticed any difference,but there again i aint been on the limits much latley. Link to comment Share on other sites More sharing options...
