ShamelessTT Posted June 29, 2007 Share Posted June 29, 2007 Hi all, Driving home from gym last night, my engine warning light came on. (Orange one to the left of the oil low light) and the red triangle. Anyway i pull over , lift the bonnet and everything sounds fine and its ticking over and reving up prefect. So i turn off ignition and then start it again and no lights on dash what so ever and the car runs perfect all the way time, plenty of power etc. At the time it came on i had done a like ~20 second blast of full power maybe, 90 leptops max. Any ideas cheers, maybe just a freak electrical fault? speed sensor? (it is de-restricted) Also recently my active spoiler has deployed when stationary and the light starts flashing on it! (I press the off button and it returns no problems then all is well again). Bit odd..... Si Link to comment Share on other sites More sharing options...
Class One Posted June 29, 2007 Share Posted June 29, 2007 Check for error codes and take it from there. Link to comment Share on other sites More sharing options...
Golddigga Posted June 29, 2007 Share Posted June 29, 2007 Is yours manual or auto? Mine is manual and does the same thing. It appears to be a code 42 which is a problem due to a dodgy delimiter/speedo conversion - search for code 42 for a wealth of info. If it is auto then I believe a code 42 would be noticable in the drive as it confuses the autobox! Then again I could just be talking crap as I am as mechanical as a baboon. Link to comment Share on other sites More sharing options...
ShamelessTT Posted June 29, 2007 Author Share Posted June 29, 2007 Its an auto yep, ill get the code from it tonight. Cheers for that guys. Link to comment Share on other sites More sharing options...
Guest Chumpalot Posted June 29, 2007 Share Posted June 29, 2007 Hi all, At the time it came on i had done a like ~20 second blast of full power maybe, 90 leptops max. Any ideas cheers, maybe just a freak electrical fault? speed sensor? (it is de-restricted) Si 20 seconds to 90mph... might want to get that sorted mate... :p j/k, hope you sort the problem out Link to comment Share on other sites More sharing options...
GeordieSteve Posted June 29, 2007 Share Posted June 29, 2007 Check your brake fluid Link to comment Share on other sites More sharing options...
DamanC Posted June 29, 2007 Share Posted June 29, 2007 Get your code 42 out! Link to comment Share on other sites More sharing options...
bolarbag Posted June 29, 2007 Share Posted June 29, 2007 Also Is your brake pads ok...the light comes on momentarily if they are very worn Link to comment Share on other sites More sharing options...
ShamelessTT Posted June 29, 2007 Author Share Posted June 29, 2007 Hmm i had the wheels off other week , atleast the fronts looked ok. Got the UK conversion waiting to go on just gotta get some 2 fit it, i was hoping to get it sorted this w/e but i cant find anyone with time free. I have to go to london on monday for a week so thats 150 miles each way, good brakes would b a good idea lol. My front left disc is warped you see and none of them seem to have much stopping power as they judder at high speed stopping. Pants! Link to comment Share on other sites More sharing options...
peter richards Posted June 29, 2007 Share Posted June 29, 2007 my car did the same the other week , when setting off to turbofit , got up to 80 for the first time in ages and the lights came on , slowed down and they went out . car probably thaught wtf is this , or thaught it had been nicked lol Link to comment Share on other sites More sharing options...
JustGav Posted June 29, 2007 Share Posted June 29, 2007 Also Is your brake pads ok...the light comes on momentarily if they are very worn The brake pads have no wear sensor, you are referring to the fact of the light coming on when the brake fluid is low.. Link to comment Share on other sites More sharing options...
ShamelessTT Posted June 29, 2007 Author Share Posted June 29, 2007 Cheers for the input guys, ill have a good look over it before my london trip. Link to comment Share on other sites More sharing options...
Shane Posted June 29, 2007 Share Posted June 29, 2007 Cheers for the input guys, ill have a good look over it before my london trip. If there is no fault code stored, there is every chance your brake fluid is just a tad low. However if you fill it right up bear in mind when you change your pads you may find you have too much in and will have to lose some. I had this problem a few months ago and it was CW who diagnosed it correctly. Link to comment Share on other sites More sharing options...
ShamelessTT Posted June 29, 2007 Author Share Posted June 29, 2007 I will check this.......and come to think of it i was on a hill at the time............... However i dont know whats in there already, your not suppose to mix it are ya? i was going for 5.1 ........i assume thats whats in but ive no clue. Link to comment Share on other sites More sharing options...
Class One Posted June 29, 2007 Share Posted June 29, 2007 I will check this.......and come to think of it i was on a hill at the time............... However i dont know whats in there already, your not suppose to mix it are ya? i was going for 5.1 ........i assume thats whats in but ive no clue. There's no harm in mixing a higher grade fluid than what is already in there, but I expect at some point you'll need a full flush. Link to comment Share on other sites More sharing options...
Missile Posted June 29, 2007 Share Posted June 29, 2007 Feel free to call me thick. But when you say check codes and 42 etc etc what do you mean ? Sorry:search: Link to comment Share on other sites More sharing options...
Class One Posted June 29, 2007 Share Posted June 29, 2007 follow the link on error codes and all will be revealed. Link to comment Share on other sites More sharing options...
