Sparky Posted June 21, 2007 Share Posted June 21, 2007 Hi all. My suspensions all creaky so ive decided when i get my coilovers next week i'll replace the wishbones at the same time to reduce the sqeakiness. I take it this would most likely be the problem? Link to comment Share on other sites More sharing options...
SatSport Posted June 21, 2007 Share Posted June 21, 2007 unless the actual outer balljoints are badly worn get a full set of poly bushings, like these http://www.tmengineering.net/suspension/r2racing/index.html Link to comment Share on other sites More sharing options...
jim_supra Posted June 21, 2007 Share Posted June 21, 2007 Hi all. My suspensions all creaky so ive decided when i get my coilovers next week i'll replace the wishbones at the same time to reduce the sqeakiness. I take it this would most likely be the problem? It could be a number of things, first thing you need to do before spending a shedload of money on wishbones is check all the suspension bolts are tight (wishbones, droplinks, Anti rollbar supports etc.) Anumber of people have found that squeaks, creaks and knocks have been down to this. EDIT: Including myself Link to comment Share on other sites More sharing options...
Sparky Posted June 21, 2007 Author Share Posted June 21, 2007 Cheers guys. Ill check it out when i fit the new coilovers next week. I looked at that link Satsport but unfortunatly my knowledge of suspension is very limited. If im buying coilovers should i get the "camber correction kit"? Im not sure but i dont want my tyres wearing if the suspension causes problems! Link to comment Share on other sites More sharing options...
jim_supra Posted June 21, 2007 Share Posted June 21, 2007 IMO You'd be better off getting the camber sorted at somewhere that does Laser alignment. It would be Quicker and cheaper. Link to comment Share on other sites More sharing options...
Sparky Posted June 21, 2007 Author Share Posted June 21, 2007 Yeh i have a mate at Vauxhall and they just got a new Laser alignment machine which he can use for free. Thanx for the info! Link to comment Share on other sites More sharing options...
