gavin.starr Posted June 19, 2007 Share Posted June 19, 2007 ive just reacently bought a mkiv supra twin turbo import. when i reverse around or drive out of sharp corners the car feels as though the rear wheels are jumping. difficult to explain. its as though ther rear axle is solid therefore sharp tight slow corners eg pulling out at a junction the rear end skipps and jumps. is this to do with the differential not working correctly because the wheel on the outside of the bend has to move round further than the inside wheel etc. very hard to explain is this normal or do i need to get it looked at. cheers in advance gav Link to comment Share on other sites More sharing options...
edge Posted June 19, 2007 Share Posted June 19, 2007 I can hear mine skip when doing tight slow turns and does it in others ive been in. Not to sure if it would do it if you was going round a roundabout for example Link to comment Share on other sites More sharing options...
gavin.starr Posted June 19, 2007 Author Share Posted June 19, 2007 its fine round larger circles such as rounderbouts mut does it ever so slightly round the mini ones Link to comment Share on other sites More sharing options...
edge Posted June 19, 2007 Share Posted June 19, 2007 Sounds fine to me mate. Unless all 8 or 10 supras ive seen do it have a diff problem which i doubt Link to comment Share on other sites More sharing options...
Digsy Posted June 19, 2007 Share Posted June 19, 2007 Do you know if you have a limited slip diff (LSD)? A search on here will tell you how to read your VIN plate to tell whether you have or not. Link to comment Share on other sites More sharing options...
AndyT Posted June 19, 2007 Share Posted June 19, 2007 Do you know if you have a limited slip diff (LSD)? A search on here will tell you how to read your VIN plate to tell whether you have or not. Yep. And missed you joining bud so Link to comment Share on other sites More sharing options...
gavin.starr Posted June 21, 2007 Author Share Posted June 21, 2007 im not sure if it has a lsd did u say there was a way of finding out. oh and another question do any of you lot know where i can get hold of a copy or an origional workshop manual such as a haynes manual for an mkiv supra twin turbo if so please could you let me know cheers Link to comment Share on other sites More sharing options...
Animal Posted June 21, 2007 Share Posted June 21, 2007 If you're getting a big jolt under slow tight turns and a feeling like the rear wheel has run over a housebrick, then your diff could be about to let go. This happened to me last year. One of the planetary gears had stripped a tooth and after a few days it went bang and fragged the whole diff. Check out my garage for a pic. Possibly not the best news you were wanting, but it's best to know. Hopefully it's summat of nowt. Welcome, BTW. Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 21, 2007 Share Posted June 21, 2007 It's almost certainly (99% certainly) got a tightly set plate type LSD in it, a none standard, aftermarket fitment. There are various set ups available, you would need to remove it to see if it's at all suitable for street driving, if it's what the Japs call a "2 way" type it will make the handling very iffy. If it's a 1 or 1.5 way, it will be fine *IF* you can live with the harshness and noise, and some extra rear tyre wear. There are oil additives available (from me, for example) that *MAY* quieten it somewhat. It will never be as civilised as an open diff, or the Toyota gear type LSD diff. If you had to buy one it would be pretty costly, so it's desirable if you actually want one Link to comment Share on other sites More sharing options...
gavin.starr Posted June 25, 2007 Author Share Posted June 25, 2007 if theres nothing wrong with it i think ill leave it the noise and the harshness cand be delt with im not too fussed about that. cheers for ure help gav Link to comment Share on other sites More sharing options...
