broomie Posted June 18, 2007 Share Posted June 18, 2007 tried wiring my stubby aerial into the boot interior light live yesterday and in doing so now my entire interior lights dont work and the time clock in the dash no longer works checked the 30amp fuse in the drivers footwell and this seems fine! any ideas? Quote Link to comment Share on other sites More sharing options...
Supradan Posted June 18, 2007 Share Posted June 18, 2007 I reckon you have blown up yer ecu:( Only kidding;) I wouldnt have thought the rear interior lights are on a 30A fuse try checking the other fuses you may have checked the wrong one Quote Link to comment Share on other sites More sharing options...
broomie Posted June 18, 2007 Author Share Posted June 18, 2007 the fuse box shows on the picture a 30amp fuse for doors im assuming this is for the doors as in interior and boot lights, there is no fuse for the time clock so im assuming this is on the same fuse but what i dont understand is the fuse is fine but the damn things still dont work! Quote Link to comment Share on other sites More sharing options...
edge Posted June 18, 2007 Share Posted June 18, 2007 I wouldnt have thought the rear interior lights are on a 30A fuse try checking the other fuses you may have checked the wrong one Quote Link to comment Share on other sites More sharing options...
Supradan Posted June 18, 2007 Share Posted June 18, 2007 Check out this thread it has a pdf of all fuse locations It is a 7.5A under bonnet labelled DOME http://www.mkivsupra.net/vbb/showthread.php?t=98378&highlight=fuse+diagram Quote Link to comment Share on other sites More sharing options...
AndyT Posted June 18, 2007 Share Posted June 18, 2007 What happened to the wire going to the original aerial then Broomie. Should have been a straight forward swap. According to the installation guide anyway. Quote Link to comment Share on other sites More sharing options...
broomie Posted June 18, 2007 Author Share Posted June 18, 2007 cheers fellas ill give that a go! Quote Link to comment Share on other sites More sharing options...
broomie Posted June 18, 2007 Author Share Posted June 18, 2007 What happened to the wire going to the original aerial then Broomie. Should have been a straight forward swap. According to the installation guide anyway. cheers fellas everything is now working fine now dome fuse replaced! andy, my original electrical aerial wire was not live (it never did work) and could not find the fuse for it so i thought id find the nearest alternative live for it i.e. boot light! Quote Link to comment Share on other sites More sharing options...
