Matt _Aero top_ Posted June 4, 2007 Share Posted June 4, 2007 Hi I'm in the process of buying some 19 inch rims for my sup but im unsure of what offset these should be ? there 8.5 fronts and 9.5 rears i understand that they've got to be 5x114 P.C.D but what offset would be best suited to my j-spec with standard brakes ? Also what tyre sizes should i be thinking of fitting please . Many thaks fellas Link to comment Share on other sites More sharing options...
Gaz Walker Posted June 4, 2007 Share Posted June 4, 2007 The offsets available will vary from company to company, but high thirties and anything in the forties will work. The design of the wheel comes into play as well. If you let me know what wheeels your looking at I can tell you more Gaz. Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted June 4, 2007 Author Share Posted June 4, 2007 Cheers gaz there axis milarno and the blokes just got back to me and he said there et32 front and 38 rears Link to comment Share on other sites More sharing options...
bolarbag Posted June 4, 2007 Share Posted June 4, 2007 Where they on a Supra before? Mine, fit J-Specs perfectly, but no chance the fronts will go over U.K Spec brakes, maybe with spacers! Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted June 4, 2007 Author Share Posted June 4, 2007 No there brand new and i have no intensions to convert to uk brakes .... well not in the near future anyway ...lol Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted June 4, 2007 Author Share Posted June 4, 2007 so is this offset ok fellas Link to comment Share on other sites More sharing options...
Gaz Walker Posted June 4, 2007 Share Posted June 4, 2007 I'd say they should be fine with the J-specs... Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted June 4, 2007 Author Share Posted June 4, 2007 Cheers gaz your a star and i ow ya a pint if we ever meet , What tyre sizes should i think of running on these ? Link to comment Share on other sites More sharing options...
Gaz Walker Posted June 4, 2007 Share Posted June 4, 2007 No worries. 245/35/19 & 275/30/19 would be a good size. Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted June 4, 2007 Author Share Posted June 4, 2007 Cheers mate but why can't you have 35 profile on the rears Link to comment Share on other sites More sharing options...
Gaz Walker Posted June 4, 2007 Share Posted June 4, 2007 Cheers mate but why can't you have 35 profile on the rears You can - although your speedo would be more out with a 35 profile than a 30... Gaz. Link to comment Share on other sites More sharing options...
ellis Posted June 5, 2007 Share Posted June 5, 2007 Cheers mate but why can't you have 35 profile on the rears Standard tyre sizes have 5mm difference too - 45 on the front 40 on the rear. Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted June 5, 2007 Author Share Posted June 5, 2007 I'm just wanting to keep asmuch profile as possible as to help prevent damaging the rims as sometimes i have to mount curbs to park the car outside my house . Link to comment Share on other sites More sharing options...
Gaz Walker Posted June 5, 2007 Share Posted June 5, 2007 I'm just wanting to keep asmuch profile as possible as to help prevent damaging the rims as sometimes i have to mount curbs to park the car outside my house . Your going to curb them then - quite easily I'd say! Doesn't really matter what tyre you get. Gaz. Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted June 5, 2007 Author Share Posted June 5, 2007 I got 40 profile on my 18's and there ok Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted June 5, 2007 Author Share Posted June 5, 2007 Hows about if i put 40's on the front and 35's on the rear or would that just be silly on 19's Would they scrape , and how much would the speedo be out ? and is there anyway of calculating this Link to comment Share on other sites More sharing options...
merckx Posted June 5, 2007 Share Posted June 5, 2007 I've got 8.5" & 9.5" on 19's Like Gaz said , 245/35 and 275/30 are the ones to go for. I fitted these on mine. The rears are only 2% different to stock ones in terms of diameter . Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted June 5, 2007 Author Share Posted June 5, 2007 I've got 8.5" & 9.5" on 19's Like Gaz said , 245/35 and 275/30 are the ones to go for. I fitted these on mine. The rears are only 2% different to stock ones in terms of diameter . You got any pics of them please mate just to get an idea of what they'll be like ? Sorry to be a pain lads i'm just worried i've spend all this money and i'm gonna wreck them now straight away . Link to comment Share on other sites More sharing options...
merckx Posted June 5, 2007 Share Posted June 5, 2007 Are you worried that if you get tyres with a lower wall height they'll give less protection for the wheels when you encounter kerbs etc? Edit. I've just read why you need them ! Link to comment Share on other sites More sharing options...
merckx Posted June 5, 2007 Share Posted June 5, 2007 Stock sizes are in bold Front 235/45 17 = 643mm dia 245/35 19 = 654mm dia 245/40 19 = 679mm dia Rear 255/40 17 = 636mm dia 275/30 19 = 648mm dia 275/35 19 = 675mm dia You might have clearance issues with the larger sidewall tyres. I wouldn't recommend getting 19's if you need to go up kerbs , unless you make some wooden ramps. Link to comment Share on other sites More sharing options...
Bob Posted June 5, 2007 Share Posted June 5, 2007 Standard tyre sizes have 5mm difference too - 45 on the front 40 on the rear. The profile is a percentage of the tyre width, not a set measurement in mm. Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted June 5, 2007 Author Share Posted June 5, 2007 Guess i'm just gonna feck my new rims up then unles anyone want a set of 19 inch axis milano's Link to comment Share on other sites More sharing options...
