Mkiv Lsd
SimonR
Hello everyone,
At the Crail Thrash last Sunday I was soundly trounced by AndyTT and Bedlam (both registered users on this forum). We all have Twin Turbo Soarers, by the way.
My terminals are OK (103.4 mph) but my starts and 60ft times are rubbish and I'm putting this down to traction difficulties. Limited Slip Diffs for Soarers are like hens teeth in this country but I'm advised that one from a MKIV Supra will fit.
Can anyone confirm this and, if so, does anyone have one for sale?
Thanks.
AFAIK the MKIV TT LSD will fit, as a complete, cased unit, but you may have to change the propshaft to one with a shorter rear section, also the drive shafts may differ. The MKIV TT diff uses two rubber mountings at the top, the Soarer only one, but the subframe has an empty hole waiting to accept the second one. Personally, if you are into drag racing, I think you are wasting your time buying a Supra LSD, it's not a suotable unit for that purpose, import a plate type 2 way LSD from Japan or the US and get it fitted to your unit.
OK A = the size of the diff. Any JDM auto Supra LSD will fit and any late ( VVTi ) diff manual or auto. Early JDM manuals and all UK diffs are B type which are much bigger.
02 = the auto gearing on a Supra from memory
HTH
"A" denotes size? I believe that Soarer diff codes are:
A01A - 3.916 ratio Open Centre
A01B - 3.916 ratio Torsen LSD
A02A - 4.083 ratio Open Centre
A02B - 4.083 ratio Torsen LSD
(Higher ratio for the V8).
Or could it be that the first A is the size and the second is the open/LSD?
The A diff is pyshically smaller than a B. The B is a Monster
The codes are similar
an A02A = an open auto Diff
an A03B = a Torsen Manual LSD
Originally posted by SimonR
Too true, mate. If I wasn't a cheapskate I would be driving a Supra not a Soarer:)
LMAO don't forget to tell Mycroft;)
