Xenon bulbs
Trig
  • 1 month later...
Originally posted by green_dragon
...some BS about not being suitable for plastic lenses, 'cos they'll melt the housing and the wiring loom'. Is it safe to say this is tosh??
I've only got the 100W bulbs in my highbeam and they've been fine so far. Mind you, I don't usually drive around with my highbeam on so they don't get a chance to melt anything.
Aren't pretty much all headlights made from plastic apart from the lens?
Should be good for those jap lenses with condensation problems! :D :D
Roy.
  • 3 months later...
ive got real xenon bulbs,
to many people talk about xenons, and get confused with blue tint halogens, silly look....
if ya want a xenon bulb contact me [email protected]
Tech Specs,
spec of philips d2s....
Lamp Power:
35 Watts
Lamp Current:
0.45 Amps
Lamp Voltage:
85 Volts
Cap:
P32d-2
Bulb Finish:
UV-Block Quartz
Bulb Type:
T-9
Overall Length:
77.5 mm
Light Centre Length:
27.1 mm
Electrodes:
Thoriated Tungsten, 4.2mm arc length
Atmosphere:
Xe | Hg, NaI, ScI3
Luminous Flux & Efficacy
3,200 lm
Luminance & Beam angle:
91 lm/W
Colour Temperature & CRI:
CCT: 4100K
CRI: Ra 65
Chromaticity Co-ordinates:
CCx: 0.380
CCy: 0.390
Burning Position:
Horizontal
Rated Life:
3000 hours
Warm Up / Re-strike Time:
5 seconds to 80% lumens Instantaneous
