gaz1 Posted May 8, 2007 Share Posted May 8, 2007 how do you use this i have a digi adjuster but not a clue how to use it, is there a manual on using rltc:search: Link to comment Share on other sites More sharing options...
Lucifer Posted May 8, 2007 Share Posted May 8, 2007 just hold the button Link to comment Share on other sites More sharing options...
gaz1 Posted May 8, 2007 Author Share Posted May 8, 2007 just hold the button you mean push it in and hold Link to comment Share on other sites More sharing options...
grahamc Posted May 8, 2007 Share Posted May 8, 2007 then put your foot on the accelerator Link to comment Share on other sites More sharing options...
Lucifer Posted May 8, 2007 Share Posted May 8, 2007 Yes - but YOu will most proble need a new map to enable it after manual upgrade. SHoudl be setup again really. Link to comment Share on other sites More sharing options...
gaz1 Posted May 8, 2007 Author Share Posted May 8, 2007 Yes - but YOu will most proble need a new map to enable it after manual upgrade. SHoudl be setup again really. mmmmm ok how do i do that Link to comment Share on other sites More sharing options...
