baldy Posted April 29, 2007 Share Posted April 29, 2007 i need help, im at a point i could take a hammer to the fcuking car now i turn ignition on and sit there all ok manu mode will come on and switch off all good. i then start the engine all is well for about 8-9 secs then the o/d lights starts to flash and manu mode will not work. ive had all the dash trims off clocks out,but every thing looks ok to me,i had the trottle body off aswell so even cut the loom open to see if id broken a wire around there,but again all looks ok to me. couild i have shorted something and spiked the ecu,trac ecu maybe also forgot if i turn the ignition off for a few seconds its like its reset itself the fault not there straight away it takes the 8-9 secs of running before the o/d lights starts to flash again please help me i need to get out in my car again, Link to comment Share on other sites More sharing options...
Ian C Posted April 29, 2007 Share Posted April 29, 2007 What do you mean by fault code 89? They don't go up that high. What about your throttle position sensor. Has that been disturbed? -Ian Link to comment Share on other sites More sharing options...
baldy Posted April 29, 2007 Author Share Posted April 29, 2007 fault code 89 on auto trans in my manual it says trc ecu circuit all conditions below are detected for 5 seconds or more (a)no1 speed sensor. 9kmh or more (b)mirror check of trc ecu input signal is abnormal ©trc ecu input signal does not inform to engine and ect ecu (d)trc ecu input signal order is abnormal Link to comment Share on other sites More sharing options...
Ian C Posted April 29, 2007 Share Posted April 29, 2007 Oh it was an autobox error code, not an engine one? You didn't say Probably your speed sensor, the usual issue with a delimiter/convertor? -Ian Link to comment Share on other sites More sharing options...
baldy Posted April 29, 2007 Author Share Posted April 29, 2007 hi ian sorry for not being clear so are you saying the speed sensor needs replacing? cheers for your help on this cheers simon Link to comment Share on other sites More sharing options...
