fault code 89
baldy
i need help,
im at a point i could take a hammer to the fcuking car now
i turn ignition on and sit there all ok manu mode will come on and switch off all good.
i then start the engine all is well for about 8-9 secs then the o/d lights starts to flash and manu mode will not work.
ive had all the dash trims off clocks out,but every thing looks ok to me,i had the trottle body off aswell so even cut the loom open to see if id broken a wire around there,but again all looks ok to me.
couild i have shorted something and spiked the ecu,trac ecu maybe
also forgot if i turn the ignition off for a few seconds its like its reset itself the fault not there straight away it takes the 8-9 secs of running before the o/d lights starts to flash again
please help me i need to get out in my car again,
fault code 89 on auto trans
in my manual it says trc ecu circuit
all conditions below are detected for 5 seconds or more
(a)no1 speed sensor. 9kmh or more
(b)mirror check of trc ecu input signal is abnormal
©trc ecu input signal does not inform to engine and ect ecu
(d)trc ecu input signal order is abnormal
