Chase Posted August 17, 2004 Share Posted August 17, 2004 I've recently fitted an RSR to my GZ, second cat is in, first is out. Car was boosting around 1.1-1.2 bar (actually KG cm2, but close enough), so I put in a restrictor ring as I found it a bit worrying , The car now boosted to around 0.9 bar. I've since swapped the plugs out for NGK BKR7E's, but decided to remove the ring again. Car's pulling really strong and is boosting to just over 1.1 bar. I've been doing a lot of reading of old threads for the past few days, and can't decide whether I need a Walbro and/or fuel computer. Some threads seemed to conclude it's necessary, others that the standard fuelling is fine to 1.2 bar (and a bit more). I've not got a FCD fitted. Should I be worried about fuelling or not? Should I get the fuelling checked on a RR? Should I just get a Walbro/SAFC anyway? Any input appreciated Cheers Link to comment Share on other sites More sharing options...
Nic Posted August 17, 2004 Share Posted August 17, 2004 Chase, it is very difficult to say whether you need to upgrade the fueling or not as it seems to vary from car to car. When I had mine dyno'd at 1.2bar on stock fuel system it was running lean, e-manage, pump and adjustable fuel pressure regualtor sorted the problem. I would recommend getting it tested on a dyno to find out, it is a lot cheaper than an engine rebuild. Link to comment Share on other sites More sharing options...
Chase Posted August 17, 2004 Author Share Posted August 17, 2004 Cheers for that Nic - Think that's probably the way to go, get it checked on a rolling road and then rectify anything that needs it. Link to comment Share on other sites More sharing options...
Matt Harwood Posted August 17, 2004 Share Posted August 17, 2004 Personally, I'd get a Walbro anyway. Assuming it's the original pump, it's probably quite tired by now. For £80-90, it's a fairly cheep, preventative, worthwhile modification. Especially if you're looking at doing more in the future. All IMHO of course Link to comment Share on other sites More sharing options...
Chase Posted August 18, 2004 Author Share Posted August 18, 2004 Matt do you (Vortex) supply the 342? Link to comment Share on other sites More sharing options...
Matt Harwood Posted August 18, 2004 Share Posted August 18, 2004 Yep. £88 + carriage. That wasn't my reason for the advice though. It was one of the first things I did on my car after increasing the boost... Cost me double that price at the time though! Link to comment Share on other sites More sharing options...
SUPRA2000 Posted August 19, 2004 Share Posted August 19, 2004 hi how much psi is 1 bar??? Link to comment Share on other sites More sharing options...
Chase Posted August 19, 2004 Author Share Posted August 19, 2004 About 14.5 http://www.maribi.com/conversion/pressuredifference.htm Link to comment Share on other sites More sharing options...
Chase Posted August 19, 2004 Author Share Posted August 19, 2004 How much is 'carriage' Matt? Link to comment Share on other sites More sharing options...
Willson Posted August 19, 2004 Share Posted August 19, 2004 Originally posted by Chase Car was boosting around 1.1-1.2 bar ........I've not got a FCD fitted. Thats not possible is it ? (without very obvious consequences) Unless you have a different ecu ? Link to comment Share on other sites More sharing options...
Chase Posted August 19, 2004 Author Share Posted August 19, 2004 Fuel cut is 1.2 bar isn't it? My boost gauge reads in KG/cm2 which is about 1.18 bar, so I've not hit fuel cut. Standard ECU btw. Link to comment Share on other sites More sharing options...
Matt Harwood Posted August 19, 2004 Share Posted August 19, 2004 Originally posted by Chase How much is 'carriage' Matt? Carriage is £9.75 Link to comment Share on other sites More sharing options...
Matt Harwood Posted August 19, 2004 Share Posted August 19, 2004 Originally posted by Chase Fuel cut is 1.2 bar isn't it? My boost gauge reads in KG/cm2 which is about 1.18 bar, so I've not hit fuel cut. Standard ECU btw. I could be wrong, but I'm sure fuel cut is at 1 bar, for longer than 4 seconds... Link to comment Share on other sites More sharing options...
Chase Posted August 19, 2004 Author Share Posted August 19, 2004 ooh - Better go and have a drive and check the boost then Link to comment Share on other sites More sharing options...
Chase Posted August 19, 2004 Author Share Posted August 19, 2004 Been out for a spin, but roads are a bit wet. Boosted to 1+ bar for about 4 seconds, and then something happened. Power seemed to go as I was fumbling the shift from 2 to D, but no warning light on the dash. Video http://www.chasewebdesign.co.uk/supra/boosting.wmv (~500Kb) I'm gonna try again tomorrow. Link to comment Share on other sites More sharing options...
Willson Posted August 19, 2004 Share Posted August 19, 2004 Yeah, testing boost pressure in the wet is always interesting I hope you were trying to read the gauge at the same time too ! Link to comment Share on other sites More sharing options...
Chase Posted August 19, 2004 Author Share Posted August 19, 2004 Gear selector in left hand, video camera in right hand, right foot on accelerator and steering with left knee No - Fixed the camcorder to the seat and pointed it at the boost gauge. Also wired it through the DVD player so I could review it on my screen. Link to comment Share on other sites More sharing options...
Chase Posted August 20, 2004 Author Share Posted August 20, 2004 Matt, I want one of these pumps - How do I go about purchasing...? Cheers Link to comment Share on other sites More sharing options...
Matt Harwood Posted August 20, 2004 Share Posted August 20, 2004 Contact Miggles Link to comment Share on other sites More sharing options...
