jawan Posted March 29, 2007 Share Posted March 29, 2007 Hi, Silly one, is the standard spring used on Mkiv N/A and TT and VVti are same or are they different in anyway. THANKS:) Link to comment Share on other sites More sharing options...
Ian W Posted March 29, 2007 Share Posted March 29, 2007 only difference is jspec to UK spec iirc. (having said that, by the time VVTi came into play there *could* have been further changes) basically, jspec are firmer than UK spec. Link to comment Share on other sites More sharing options...
JustGav Posted March 29, 2007 Share Posted March 29, 2007 There are a few different options available... HOWEVER they do physically fit the various cars without any issues. Link to comment Share on other sites More sharing options...
Nic Posted March 29, 2007 Share Posted March 29, 2007 There were lots of different springs used on the various Supra models. The NA uses a lighter spring rate and different length spring to the TT as it is a little lighter. All the springs are interchangeable with different models, although don't mix and match individual springs, fit a full set. Link to comment Share on other sites More sharing options...
jawan Posted March 29, 2007 Author Share Posted March 29, 2007 what you think about vvti springs on TT Link to comment Share on other sites More sharing options...
Nic Posted March 29, 2007 Share Posted March 29, 2007 what you think about vvti springs on TT A set of VVTi springs will be fine on a TT, I think they sit slightly lower than some of the earlier models. Even better if you also fitted a set of Bilstein dampers with them. Link to comment Share on other sites More sharing options...
