tooquicktostop Posted March 26, 2007 Share Posted March 26, 2007 I have a stock sparkplug and cam wheel cover and it needs stripping after a bad paint job and re painting, what is the best way to strip?? and then re paint Quote Link to comment Share on other sites More sharing options...
Guest mk47 Posted March 26, 2007 Share Posted March 26, 2007 Wet & dry? Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted March 26, 2007 Author Share Posted March 26, 2007 I was hoping a chemical of some sort as the detailing will be impossible to strip, but I am worried the chemical may attack the plastic ! Quote Link to comment Share on other sites More sharing options...
SupraAyf Posted March 26, 2007 Share Posted March 26, 2007 I have a stock sparkplug and cam wheel cover and it needs stripping after a bad paint job and re painting, what is the best way to strip?? and then re paint I would use a 320-grit sand paper to rub down the peeling paint and then you could finish it off with a 500-grit in order to prep for painting;) Quote Link to comment Share on other sites More sharing options...
supRo Posted March 26, 2007 Share Posted March 26, 2007 Use 2K/2 pac paint - the same paint as your car body or heat resistant paint. Cellulose paint will blister Quote Link to comment Share on other sites More sharing options...
baldy Posted March 27, 2007 Share Posted March 27, 2007 try a pressure washer if its been done that bad the paint will probably fall off but watch you dont get carried away and start cutting grooves in the plastic Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted March 28, 2007 Author Share Posted March 28, 2007 Well finished it today and quite pleased with myself !, used a chemical paint stripper and then sanded it down, 4 coats of primer, 5 of paint and 3 of clear coat, the white mark is the light ! Quote Link to comment Share on other sites More sharing options...
SupraAyf Posted March 28, 2007 Share Posted March 28, 2007 Good job sir;) Quote Link to comment Share on other sites More sharing options...
Kev.O Posted March 28, 2007 Share Posted March 28, 2007 What paint did you use, looking very good Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted March 28, 2007 Author Share Posted March 28, 2007 I brought it from Halfords [OOPS][/OOPS] The Blue is a ford colour, just wanted something to match the silicon hoses, will get the actual colour code if you need it Quote Link to comment Share on other sites More sharing options...
Kev.O Posted March 28, 2007 Share Posted March 28, 2007 The reason I asked is because when i done mine, I used halfords primer and plasticote finish but it flaked off on the fuse box lid. Quote Link to comment Share on other sites More sharing options...
Lucifer Posted March 28, 2007 Share Posted March 28, 2007 Nitromorose. Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted March 29, 2007 Author Share Posted March 29, 2007 Yes I used Nitromorse to remove the several poor layers of paint until it was back to clean plastic, this did no damage to the plastic which I was worried about, I then used a Plastic primer, will have to see if it lasts! Quote Link to comment Share on other sites More sharing options...
