lowering probs
richy2jz-gte
since i lowerd my car with yellow billies and eibach springs im getting a nocking from the front suspension when i go over speed bumps i only removed the bottom shocker bolt and the 3 top strut bolts to change it but all these are tight. and all suspension bushes and linkages seem fine i aint checked the front antiroll bar bushes yet though. any ideas:conf:
i tryed doing it by the book but the first bolt i tryed to undo snapped off so i just undone the 3 top strut bolts and the bottom leg bolt got a bar and pushed down the bottom arm and pulled the strut out same on the back but you have to remove the rear caliper from the back because the leg wont clear the brake flexi. now i know how to do it i could easly do the whole job in less than 1 1/2 hours. my car was knocking before but its just 10 times wosre now ive lowerd it probably because its loads harder.
found out what it is.... when i tryed doin it "by the book" i tryed undoing the antirollbar links off but the whole lot kept turning and the alan key rounded off cus its old and crusty so i thought it was still tight but its not it must have undone slightly and is knockin in the antiroll bar.
i rang toyota and they want £50 for 1 so i asked 1 of our supplyers and they got a genuine part but in a diffrent bag for £20.....
