N/A drivers, which plugs do you use ?
Rory
I see the list for spark plugs in the FAQ section , what I'd like to know is what you guys use and find good ?
Are the V power NGK worth the extra over standard ? What would you recommend ?
NGK - Standard - BKR5ES-11 (2382) - gap 1.1mm
NGK - V-Power - BKR5EYA-11 (2526) - gap 1.1mm
NGK - G-Power Platinum - BKR5EGP (7090) - gap 1.1mm
NGK -Laser Platinum - BKR5EP-11 ( 3440) -gap 1.1mm
NGK -OE Laser Iridium - IFR5T11 (4996) - gap 1.1mm
NGK - Iridium IX - BKR5EIX-11 (5464) - gap 1.1mm
Denso Platinum - PK16R11 - gap 1.1mm
