Jason Posted February 25, 2007 Share Posted February 25, 2007 I have fitted new water temp, oil temp and oil pressure gauges today. I just wondered now that I have all pretty lights and numbers in front of me, what are the correct values for each of the gauges? My car is a standard J-Spec if that should make any difference. Thanks, Jason Quote Link to comment Share on other sites More sharing options...
Rory Posted February 25, 2007 Share Posted February 25, 2007 Did you find it difficult to tap into oil and water feeds for the senders? This is something I would like to do at some point. Quote Link to comment Share on other sites More sharing options...
Jason Posted February 25, 2007 Author Share Posted February 25, 2007 I used a sandwich plate for the oil senders, but becaue I have stainless pipes, I had to have a nut welded on for the water sender to screw into. Quote Link to comment Share on other sites More sharing options...
AlanM Posted February 25, 2007 Share Posted February 25, 2007 Did you get the sandwich plate from eBay, one with 4 points for offtake of readings? Quote Link to comment Share on other sites More sharing options...
Jason Posted February 25, 2007 Author Share Posted February 25, 2007 I got the plate from Nick at http://www.gaugeplace.co.uk It is the one with 4 points and comes with blanking screws aswell. Quote Link to comment Share on other sites More sharing options...
AlanM Posted February 25, 2007 Share Posted February 25, 2007 is there o-rings on the blanking screws? And why would anyone want 4 points? Quote Link to comment Share on other sites More sharing options...
Jason Posted February 25, 2007 Author Share Posted February 25, 2007 I put PTFE tape on the screws and senders, there is 4 holes so that the sendres are easy to put in and get to when you connect the wires. But, does anybody know what the true readings should be? Quote Link to comment Share on other sites More sharing options...
supra matt Posted February 25, 2007 Share Posted February 25, 2007 water temp should be 80 to 90 deg oil should be 80 when hot and anything upto 120 when your raging the car , oil pressure any thing over 18 psi on idle's good Quote Link to comment Share on other sites More sharing options...
Jason Posted February 25, 2007 Author Share Posted February 25, 2007 Cheers Matt, my gauges are reading about right then. Quote Link to comment Share on other sites More sharing options...
supra matt Posted February 25, 2007 Share Posted February 25, 2007 no worrys mate nice car to , Quote Link to comment Share on other sites More sharing options...
merckx Posted February 25, 2007 Share Posted February 25, 2007 Did you get the sandwich plate from eBay, one with 4 points for offtake of readings? I did, fitted it on Friday. Quote Link to comment Share on other sites More sharing options...
Rory Posted February 25, 2007 Share Posted February 25, 2007 Id really like to do this, would like to fit them in the space I have above my radio in the spare DIN slot. Quote Link to comment Share on other sites More sharing options...
