far Posted July 2, 2004 Share Posted July 2, 2004 In the lude when I am doing 60+ and I brake firmly I get a shaking/vibration feedback on the steering wheel. I noticed this before I changed my pads but thought it was because the pads where getting low. I know have new OEM pads and the feedback persists,could this be warped disc(s) sticky caliper ? Honda didnt notice any problems when they did the service/pad change a week or so ago I hope its ok posting this in tech as its not supra related Link to comment Share on other sites More sharing options...
attilauk Posted July 2, 2004 Share Posted July 2, 2004 sounds like a warped disc to me, my sup is doing that too cos i warped a disc on Castle Coombe:p Link to comment Share on other sites More sharing options...
SkyJawa Posted July 2, 2004 Share Posted July 2, 2004 Can also be wheel balance mate.......... Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 2, 2004 Share Posted July 2, 2004 Probably a warped front disc(s), although it's not common. I can check them properly with a dial test indicator, and have new ones in stock. Also new J-Spec front and rear calipers, NOT Lexus ones with wrong piston size, correct Supra TT ones. Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted July 2, 2004 Share Posted July 2, 2004 Originally posted by Chris Wilson Probably a warped front disc(s), although it's not common. I can check them properly with a dial test indicator, and have new ones in stock. Also new J-Spec front and rear calipers, NOT Lexus ones with wrong piston size, correct Supra TT ones. His talking about his Prelude Chris, not a Soop. Ben.. Link to comment Share on other sites More sharing options...
Justin Posted July 2, 2004 Share Posted July 2, 2004 I had this on the steering wheel too mate. It was wheel balancing, stuck REAR calipers and knackered rear disks. Link to comment Share on other sites More sharing options...
far Posted July 2, 2004 Author Share Posted July 2, 2004 Ah ok - cheers guys,is it safe to drive with warped discs ? i.e. would they cause more damage to anything ? Its only apparant on firm to heavy breaking when stopping from higher speeds. Also any ideas what causes discs to warp ? Link to comment Share on other sites More sharing options...
SkyJawa Posted July 2, 2004 Share Posted July 2, 2004 heat sitting with your foot on hot brakes at traffic lights is great for warping disks, hence why you should use a handbrake - and it also helps to stop dazzling people behind you (the you above is not aimed at you, but generic drivers who do such things ) Warped disks are fine unless its severe. Just irritating. Link to comment Share on other sites More sharing options...
far Posted July 2, 2004 Author Share Posted July 2, 2004 Cool - cheers dude,its been there since I got the car so it must have been the previous owner:twak: I'll probably just leave it then since Im getting rid soon Link to comment Share on other sites More sharing options...
SkyJawa Posted July 2, 2004 Share Posted July 2, 2004 Might as well mate Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 2, 2004 Share Posted July 2, 2004 Originally posted by Soonto"HAS"soop His talking about his Prelude Chris, not a Soop. Ben.. Ah! It all becomes clear now. I'm old.... Thanks. Link to comment Share on other sites More sharing options...
SkyJawa Posted July 2, 2004 Share Posted July 2, 2004 LOL @ Chris Link to comment Share on other sites More sharing options...
Ambrose7 Posted July 6, 2004 Share Posted July 6, 2004 i had the exact same problem with my jspec, turned out to be sticky front caliper Link to comment Share on other sites More sharing options...
dangerous brain Posted July 6, 2004 Share Posted July 6, 2004 My poxy sierra does this all the time now. The previous sierra I had also did it. When it gets so bad that it does it even at low speeds I change the discs and it goes away. Probably doesn't do ball joints and other misc suspension parts much good long term but you aren't keeping long term so not really an issue for ya. Link to comment Share on other sites More sharing options...
