Slow water leak
Rob
Further to my post about the pipe rattling about at the rear of the engine bay, it transpires my expansion tank is empty and there is water all around the undertray, which I though was due to wet weather.
Obviously, something is leaking somewhere but if I just want to top up until I get car into a garage, is there just one type of Toyota coolant (the red stuff) or will it be a special order?
when mine was leaking it turned out to be water coming out of overflow pipe on waterpump, new waterpump sorted it. also the big water pipe at back of engine started leaking when i tried to take it off to change, it would not stop leaking put jubilee clip on it and it stopped water leaking.
Most of the water in the under tray appears to be around the air con pump area on the RH side.
Odd though, just drove to Toyota to get some coolant, after putting a bit of water in, and the temp rose while sitting in very slow traffic, but then as it got to the red line it dropped suddenly.:blink: :blink: Did it again on the way home as well.
  • 2 weeks later...
Update. Toyota pressure tested the rad and no leaks appeared, but they told me the power steering pump was leaking.
I don't know if he was offering that as a solution to my dropping coolant level, if he was, he's an idiot.
And 8.3km on the clock for a test drive for a minor service, seems a bit long to me.
Still £158 is a better price than I used to pay down south.
