baldy Posted June 20, 2004 Share Posted June 20, 2004 ok my car is stuck in the garage off the road,the ba\ttery is now flat.so im looking at getting a battery conditioner any one got any recomendations on a particular make n model cheers baldy Link to comment Share on other sites More sharing options...
Steve Cargill Posted June 20, 2004 Share Posted June 20, 2004 Once a lead-acid battery drops below about 80% charge then it starts to sulpherate and that is not reversable. You can get deep discharge batteries designed for caravans etc, but a car battery is designed to stay charged and give short high capacity loads. A normal charge should do it, but it's life may well have been shortened. If it's one you can top it up then always top it up when it's fully charged. I've never used or know anything about conditioners. The solar panel trickle chargers are meant to be OK, if you can get the sunlight into your garage. Link to comment Share on other sites More sharing options...
Terminator Posted June 20, 2004 Share Posted June 20, 2004 Get a float charger it will keep your battery going for ever. Link to comment Share on other sites More sharing options...
