Clarkey Posted June 2, 2004 Share Posted June 2, 2004 Hi, When I had my MR2 Turbo it had CC. Which was handy, for motorway driving - especially for petrol economy. My Supe doesn't have CC - does anyone know of a CC kit you can buy ? Ta. Christian. Link to comment Share on other sites More sharing options...
Matt Harwood Posted June 2, 2004 Share Posted June 2, 2004 I assume you mean aftermarket? - Possibly... I'll find out tomorrow... Link to comment Share on other sites More sharing options...
Alex Posted June 3, 2004 Share Posted June 3, 2004 You can get the stocl system and wire it in. PM Soop Dogg - he's done it. Unless he comments here. Link to comment Share on other sites More sharing options...
Branners Posted June 3, 2004 Share Posted June 3, 2004 You can wire it in but it needs stuff wired in to various looms, if the car is missing the cruise then the connector from under the bonnet back in to the car will also be missing so you have to get that and run it through the bulkhead. JB Link to comment Share on other sites More sharing options...
Soop Dogg Posted June 3, 2004 Share Posted June 3, 2004 Originally posted by Branners You can wire it in but it needs stuff wired in to various looms, if the car is missing the cruise then the connector from under the bonnet back in to the car will also be missing so you have to get that and run it through the bulkhead. JB I have always found this plug to be present on cars NOT fitted with cruise. Just the other day someone asked about what some unconnected plugs were for and they turned out to be for Cruise. My first '93 RZ didn't have cruise but it had all the wiring and plugs. But then my second '93 RZ only appeared to have the plug under the bonnet, not the 26 pin green plug behind the dash for the cruise ECU. The one under the bonnet, by the way connects straight into the cruise actuator. If you are thinking of wiring up the stock Toyota unit, be prepared for ALOT of work. Cruise requires inputs from speed sensors, brake pedal (Actually needs the dual contact brake switch, normally these are single contact) gear lever (to switch off cruise when you hit neutral), handbrake etc. etc. Takes ages! It is a good excercise in getting to know your car though! It also utilises power supplies form 3 different circuits. Only weeks after installing it on my car, I went and bought a GZ which already has it installed! DOH!! Link to comment Share on other sites More sharing options...
