Fitting replacement side repeaters.
sdavies
Quick question - how easy is it to pop the side repeaters out of a standard pre-facelift wing and replace with my naff yet funkier than yellow - clear indicators? - well let me re-phrase that - how does one go about it? [Feel free to rebuke me if this is covered in an obvious FAQ, but my searches haven't revealed any specific advice so far].
I assume it is so easy that I have wasted vital electrons posting this message, but I have been known to approach a simple thing from all the wrong angle and end up beating with a hammer and hacksaw - only to find out turning the dohicky anti-clockwise would have removed it with no bother!!! (I am also worried about *just applying pressure* - to bits I am unsure are designed to take a bit of pressure).
Any help/advice on this hopefully trivial matter greatfully received :D
* dons asbestos suit hoping to be treated gently *
They should just pop out, i used a knife with a cloth against the bodywork and just eased it out. You push the repeater towards the back of the car i think to get it started then ease it outwards.
You'll realise how to do it when you see the design of your replacement side repeater!
I had no idea it was in fact so easy I may as well go and die in shame for asking ;) Finger-Thumb small tug they came out - pulled wire out a bit, popped clear bulb out - put yellow bulb in. Slotted back into indicator - popped in - grand total of about 60 seconds per side - ROFL. They do make a huge difference to the look - I hadn't realised! (The little things eh?).
Thanks again guys :D
:thumbs:
