Matt _Aero top_ Posted December 9, 2006 Share Posted December 9, 2006 Over the last few days i've noticed a strange noise coming from arond the power steering pump . Not quite sure what it can be hopefully i think its just the belt thats wanting changing .... Heres the symptoms. It does it when cold and makes a quite loud sound but goes away once the engines warmed up. also just out of curiousity the other day when the car was still cold and the noise was quite loud i gave it a quick blast of WD40 and it went silent . Any ideas fellas ?? does this sound like just a new belt needed or is it more serious like bearings in the pump ? Forgot to say that the belt doesn't look that bad . Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted December 9, 2006 Author Share Posted December 9, 2006 Anyone ??? Link to comment Share on other sites More sharing options...
Nic Posted December 9, 2006 Share Posted December 9, 2006 It will be either the belt slipping, or low fluid. If the fluid is low and air has got into the system then pump will make a 'groaning' noise as you turn the wheel. If it is the fluid top up and bleed ASAP, as you'll soon damage the pump otherwise. Link to comment Share on other sites More sharing options...
D8MOA Posted December 9, 2006 Share Posted December 9, 2006 ive found before that the powersteering cooler pipes leak where the bolt brackets are brased on! check these other will you may be looking for hours lol if it is low fluid that is Link to comment Share on other sites More sharing options...
Nic Posted December 9, 2006 Share Posted December 9, 2006 Yes water on the belt can make them slip and squeel, have you washed your engine bay recently? Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted December 11, 2006 Author Share Posted December 11, 2006 No not washed the engine bay . But it needs doing badly ... lol.... Checked the fluid when the engine was hot after a drive home from work and the level mark was on cold so i topped up to the hot mark . So i'll see what tommorow brings . Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted December 11, 2006 Author Share Posted December 11, 2006 Quick question though ..... whats the bast way to bleed the system ? Is it just leave the cap off and turn for steering from lock to lock ? How many times should i do this ? Link to comment Share on other sites More sharing options...
uksupra Posted December 11, 2006 Share Posted December 11, 2006 mine was making strange noise so i just tried bleeding it and funnily enough loads of air bubbles appeared and once cleared its been fine since... £400 for a pump is not a nice xmas pressie! Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted December 11, 2006 Author Share Posted December 11, 2006 How did you bleed it ? Link to comment Share on other sites More sharing options...
lui Posted December 11, 2006 Share Posted December 11, 2006 How did you bleed it ? release power steering cap full lock from side to side & holding it for about 5-10 seconds in full lock repeat this 4-5 times that should do it & clear all air bubbles then once done let bubbles in reservior settle naturally Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted December 11, 2006 Author Share Posted December 11, 2006 release power steering cap full lock from side to side & holding it for about 5-10 seconds in full lock repeat this 4-5 times that should do it & clear all air bubbles then once done let bubbles in reservior settle naturally Chears matey. Link to comment Share on other sites More sharing options...
alan_blue Posted December 19, 2006 Share Posted December 19, 2006 did it work? Link to comment Share on other sites More sharing options...
tango Posted December 20, 2006 Share Posted December 20, 2006 how do you bleed the pump? cheers Link to comment Share on other sites More sharing options...
alan_blue Posted December 20, 2006 Share Posted December 20, 2006 as above mate Link to comment Share on other sites More sharing options...
