bolarbag Posted December 4, 2006 Share Posted December 4, 2006 Hi All, Any ideas on what aftermarket fans are available for the Supra? I want rid of the Viscous Fan to reduce rotating mass, I know the difference will be minimal but it all adds up... What manufacturers do the fans, and reliably? cost aint an issue within reason what about Flexalite?I've heard they do twins Link to comment Share on other sites More sharing options...
TLicense Posted December 4, 2006 Share Posted December 4, 2006 The general consensus is that it's really not worth it as the viscous fan is actually pretty bloody good at cooling the car. The electric ones aren't so good.... If you're still convinced check out the traders section.... Link to comment Share on other sites More sharing options...
SimonB Posted December 4, 2006 Share Posted December 4, 2006 You can't get something for nothing, if you use an electric fan all that will happen is that the alternator will cause more load on the engine, and probably more than you gain by not having the viscous fan. Link to comment Share on other sites More sharing options...
Sheefa Posted December 4, 2006 Share Posted December 4, 2006 Yep, as above mate. Spal fans are meant to be OK - I looked into one but again was advised that the Viscous one really is top trumps for cooling so don't bother pal! Greg Link to comment Share on other sites More sharing options...
Alex Posted December 4, 2006 Share Posted December 4, 2006 If you're still keen despite all our reservations then check out http://www.mvpmotorsports.com as they have some of the better kits. Link to comment Share on other sites More sharing options...
mikeyb10supra Posted December 4, 2006 Share Posted December 4, 2006 Yep, as above mate. Spal fans are meant to be OK - I looked into one but again was advised that the Viscous one really is top trumps for cooling so don't bother pal! Greg Spal fans are great but not as a replacement for the viscous unit Ive got a 13" push type one that replaced my electric fan when I fitted my FMIC...works great and keeps air moving through the rad when the air con kicks in tight squeeze but worth it Link to comment Share on other sites More sharing options...
