Paul -C- Posted May 14, 2004 Share Posted May 14, 2004 Once I drive round the 180 degree corner should the diagnostic led stop flashing, or does it continue to flash whilst the adapter is plugged in? Once I unplug the adapter it stops flashing and picks up the wheel speeds and rpm fine... Link to comment Share on other sites More sharing options...
Paul -C- Posted May 14, 2004 Author Share Posted May 14, 2004 I'm just thinking... maybe I done the turn too slow and rltc didn't pick it up cos the minimum wheel speed thing is set to 14kph... Link to comment Share on other sites More sharing options...
Terminator Posted May 16, 2004 Share Posted May 16, 2004 You must be above the speed threshold. The light will stop its setting sequence and revert to a signal from the car. If you want to be totally sure. jack up the car, re set the min speed to say 5kph and spin the wheels buy hand. I had to do my configuration a few time before the unit would set. Link to comment Share on other sites More sharing options...
