Torque?
flukey-lukey
The idler pulley is the pulley that does nothing, its quite idle ;) The belt just loops round it & it has a central bolt. If you haven't disturbed it then no need to know the torque!
A handy hint.... If you don't know the torque of a bolt then you can mark its position with a bit of tip-ex or paint across the head and the part its bolted to, then scribe a straight line throught the middle. When you fasten the bolt back up aim to take it back to this mark excatly. Should be about right.
Good advice mate, thanks! :thumbs:
All done now (i think) it made a little 'squeek' as i started it up (cold) and then went for a blast, seems to have lost the squeek :)
