Steviekid Posted October 31, 2006 Share Posted October 31, 2006 If you have a Thor speedo converter and your speedo suddenly stops working, disconnect you battery for ten minutes and it will probably start working again. DO NOT dismantle your entire dash, take the speedo to bits, remove you glo dials (which incidently stops them working when they're put back on) and spend f**king ages cutting and soldering various wires together. Link to comment Share on other sites More sharing options...
jamesmark Posted November 1, 2006 Share Posted November 1, 2006 Ahhhh now this makes sense, as my speedo stopped working after diconnecting the battery and then I had to do another job and disconnected it again and now it works. Link to comment Share on other sites More sharing options...
Mas Posted November 1, 2006 Share Posted November 1, 2006 good post mate, as Im going to disconnect my battery when Im getting some work done, atleast Im prepared now in case it happens Link to comment Share on other sites More sharing options...
RobSheffield Posted November 1, 2006 Share Posted November 1, 2006 I was the same...lost speedo after disconnecting the battery, posted up here BEFORE i pulled the dash apart, and someone suggested i leave the battery disconnected for a while Link to comment Share on other sites More sharing options...
Steviekid Posted November 1, 2006 Author Share Posted November 1, 2006 posted up here BEFORE i pulled the dash apart, Good move! Link to comment Share on other sites More sharing options...
