EMU Data logging!
Tricky-Ricky
Starting to annoy me now, it seems that the data log min and max figures must be set before logging, unlike the Innovate log where you can configure the min and max so you can match up say the peak reading on a peak hold boost gauge:(
also found that with the new version 2.0 update the Innovate AF pre set figures are wrong and wont record the same value in the new data sampling map, as in the innovate log:blink:
also found that the ing timing log will not work now! seems like they fix one bug and create another!
Well, on the plus side it's got file associations at last ;)
I can load in a logfile and set the min and max values still, what makes you think you can't?
The innovative WB is configurable isn't it? Is it not just a case of the EMU interpreting the 0-5v output differently to what you have set up?
And the ignition timing datalogging never worked for me anyway. Sometimes it'd be sane, other times it'd give me up to 200degrees... Is that the behaviour you are getting now?
No, I haven't tried it yet :p
-Ian
Kind of difficult to explain what i mean, if i open up a saved EMU data log and find that say the boost peak on the graph is not the same value as the peak on the boost gauge, and i wish to reconfigure it, as i can do with the innovate LM-1 logs, it won't change the value of the graph, only the min and max setup values,
I had the EMU timing values being logged on the 1.14 version, and apart from the occasional + 50deg glitch it was OK, now nothing.
