ECU for NA
nad300
prob a main 40amp fuse of something! check thet 1st if not i have a ecu
Hi mate, car was fine but had a flat battery so when i tryed jumping it accidently connected the leads wrong way only for few seconds but then the ignition lights etc nothing was working i have checked the fuses in the engine bay all look ok even the 7.5a ign fuse in footwell is ok, is there any other fuses a should check ?? & how much do you want for your ecu ??
there is a main car fuse... Its in the engine bay, on the far left of the fuse box... Its white ish with a clear plastic cover on it... To take it out you need to take off all the nuts holding the fuse board down, and undoing the nuts underneith that hold it on..
HTH
HTH
Good advice :thumbs:
HTH
thanks will deffo check that fuse so will that be it or is it a possibilty what size is the bolts ?? as cars at my other addy so will need it collect some tools before i get to it & has ayone got one i can buy off them ? sorry about all the questions guys hope you dont mind.[COOL][/COOL]
If that doesn't work there's one on ebay http://cgi.ebay.co.uk/GENUINE-TOYOTA-ENGINE-ECU-FOR-3000CC-AUTO-SUPRA-LEXUS_W0QQitemZ110048776913QQihZ001QQcategoryZ10428QQrdZ1QQcmdZViewItem
I know it's an auto one but apparently it will work fine on a manual (the problem is when you try to go the other way)
or try absxxx on here:)
cheerz mate will do[COOL][/COOL]
