Suspension replacement
Ian W
I'm going to be getting my suspension replaced next week, however the car is a daily driver so cant' be without it longer than the day i have allotted.
I'm just curious as to what could go wrong during this procedure that might cause a problem. am sure someone mentioned drop-links being a pain in the ass?
any info much appreciated
Ian
your old drop links will be welded on and need sawing off, mine did. And since they are cheap from MrT, could be worth getting them done at the same time. Your top mounts could also be worn and need replaced, not sure on the cost of these.
well, as i've got pennies to my name the top mounts may well have to wait :(
any idea on the cost of the drop links?
Just remembered a chat on MSN and thought you bought some coilovers?
I'll dig out my invoice for the drop links when I get home. I needed mine in a hurry so went to Toyota but if you can wait Nic is the cheapest on these :)
i dont really get the electronic adjustment feature?
what's there to get? you have a control box in the cabin that lets you adjust the damping electronically (three personalised settings i believe).
saves you getting out, lifting the bonnet and doing it manually.
