Flat - TYRE
Darren-K
Got up for work this morning,..
got a flat -
theres no sign of any foreign body`s in the wheel or anything and worse still cant get the valve cap of coss its an alumnium one and its seized on...
ATS are coming out and its £58 jus to come out and repair the tyre... :(
yeh but its a 16", the ones fitted are 19"`s
:D
damn right cancel them mate, get that spare swapped on and drive down there. make sure they give you some plastic valve caps too, blingy valve caps are more hassle than they're worth.
cheeky gets,. on the phone they said,."well mate,what were gonna do is take the wheel off,take it back to our base,repair it then bring it back"
so im doing it,. i might as well drive the with the spare on and get it fixed myself......
now then,.. wheres the jacking point for the front off side wheel anyone ? :( lol
this has turned into a hilarious job now,
none... not one ( and i have 3) of the wheel braces fit,.
theres not enough space between the edge of each nut to get anything i have in,. and the only only one that will go in is too big so will round the nuts.
you'll have aftermarket wheels (and thus aftermarket nuts) then matey. i had a similar problem and ended up buying a socket and breaker bar to keep in the boot.
you within walking distance to Halfords or somewhere similar? you'd need to know the size of the wheel nuts first mind.
