c0c4in3 Posted September 20, 2006 Share Posted September 20, 2006 Hi there, Just removed the Toyota badge on the trunk. There is a gluefilm on the paint. I tried to remove it mechanically but no chance. Any idea what shall I use to remove it? I think that petrol or acetone is not the best for the paint, right? thanks... Link to comment Share on other sites More sharing options...
Ric Posted September 20, 2006 Share Posted September 20, 2006 i just used white spirits Link to comment Share on other sites More sharing options...
Bob Posted September 20, 2006 Share Posted September 20, 2006 I scraped most of mine off with a bit of soft plastic - the spreaders you get for fibreglass are ideal. Then get any remainders off with a rag and some white spirits. A quick once over with some scratch remover / G3 / T-Cut, then reapply your usual wax. Hey presto, clean as you like. Link to comment Share on other sites More sharing options...
Guest mk47 Posted September 20, 2006 Share Posted September 20, 2006 use lighter fluid it will just slide off with a tissue. Link to comment Share on other sites More sharing options...
rovervi Posted September 20, 2006 Share Posted September 20, 2006 I have used switch cleaner in the past and it has worked a treat Link to comment Share on other sites More sharing options...
vvteye Posted September 20, 2006 Share Posted September 20, 2006 I used brake fluid... that shifted it! Link to comment Share on other sites More sharing options...
Guest mk47 Posted September 20, 2006 Share Posted September 20, 2006 I used brake fluid... that shifted it! along with a layer of paint? Link to comment Share on other sites More sharing options...
Dave Posted September 20, 2006 Share Posted September 20, 2006 I used brake fluid... that shifted it! dont listen to that man Link to comment Share on other sites More sharing options...
c0c4in3 Posted September 20, 2006 Author Share Posted September 20, 2006 i just used white spirits thanks guys. white spirit is something like ethanol? Link to comment Share on other sites More sharing options...
turnerjr Posted September 20, 2006 Share Posted September 20, 2006 use a fudge wheel mate (sometimes called a caramel wheel). goes in the end of a drill and will take about 5 seconds to get the glue off and will not damage the paint work, i use them at work all the time. Can get them from any half decent auto paint place for a few pound. Link to comment Share on other sites More sharing options...
c0c4in3 Posted September 20, 2006 Author Share Posted September 20, 2006 could you get me one? Link to comment Share on other sites More sharing options...
black cat Posted September 20, 2006 Share Posted September 20, 2006 meths........ then take a swig. Link to comment Share on other sites More sharing options...
