adi2009 Posted September 17, 2006 Share Posted September 17, 2006 Took my car out today. Was driving it quite hard, hit around 20psi of boost, and after I got back I noticed that the idling was rough and the engine was puffing out black smoke. Now does this mean my turbos are gone or is it my engine??? any help would be great cheers adi Link to comment Share on other sites More sharing options...
supra matt Posted September 17, 2006 Share Posted September 17, 2006 black smoke will be fuel mate . IT's over fueling for some reason! whats the spec? Link to comment Share on other sites More sharing options...
adi2009 Posted September 17, 2006 Author Share Posted September 17, 2006 Jspec, BPU, Full decat, been running more boost than I should Link to comment Share on other sites More sharing options...
Robert Posted September 17, 2006 Share Posted September 17, 2006 A compression test should give you a better idea Link to comment Share on other sites More sharing options...
supra matt Posted September 17, 2006 Share Posted September 17, 2006 sounds like you might of split or poped a hose off some where ! what is the highest boost you were ment to run? Link to comment Share on other sites More sharing options...
adi2009 Posted September 17, 2006 Author Share Posted September 17, 2006 Possibly 22psi Link to comment Share on other sites More sharing options...
supra matt Posted September 17, 2006 Share Posted September 17, 2006 that is high! still must of been fast . Have you got a fpr on there? it could be that ? Link to comment Share on other sites More sharing options...
adi2009 Posted September 17, 2006 Author Share Posted September 17, 2006 No mate. stock fuel pressure regulator Link to comment Share on other sites More sharing options...
Matt Harwood Posted September 17, 2006 Share Posted September 17, 2006 Do you have a boost gauge? My guess is almost certainly a hose popped off as the MAP sensor is now seeing no vacuum, it's adding fuel as if you were at 0 boost. Relax and go check your hoses Link to comment Share on other sites More sharing options...
Matt Harwood Posted September 17, 2006 Share Posted September 17, 2006 Just re-read the thread, obviously you do have a boost guage, and if you sustained 22 psi for any length of time, you may easily have melted something serious. If it was just a spike, you should be OK. Link to comment Share on other sites More sharing options...
bondango Posted September 17, 2006 Share Posted September 17, 2006 As said Black smoke is usually Fuel. You should be able to smell it too. With a Jspec being MAP based, a boost leak dosnt usually make it run as rich as a UK car but check all the Intake and IC hoses. It will be seeing 0psi if it was leaking around MAP sensor area, so holding the revs at around 3K should see the smoke clear slightly. Get the plugs out and give them a check. what plugs were you running for 20psi?? Compression check wouldnt go a miss either to be on the safe side. 20psi can do damage to a few stock items that are on there last legs - Hoses, BOV, FPR etc etc Link to comment Share on other sites More sharing options...
adi2009 Posted September 17, 2006 Author Share Posted September 17, 2006 As said Black smoke is usually Fuel. You should be able to smell it too. With a Jspec being MAP based, a boost leak dosnt usually make it run as rich as a UK car but check all the Intake and IC hoses. It will be seeing 0psi if it was leaking around MAP sensor area, so holding the revs at around 3K should see the smoke clear slightly. Get the plugs out and give them a check. what plugs were you running for 20psi?? Compression check wouldnt go a miss either to be on the safe side. 20psi can do damage to a few stock items that are on there last legs - Hoses, BOV, FPR etc etc Been running IK26 Iridium plugs Link to comment Share on other sites More sharing options...
terribleturner Posted September 17, 2006 Share Posted September 17, 2006 20-22psi on stock J-Spec Tubbies?? Link to comment Share on other sites More sharing options...
supra matt Posted September 18, 2006 Share Posted September 18, 2006 did you sort this out mate? Link to comment Share on other sites More sharing options...
