jaiscossie Posted September 9, 2006 Share Posted September 9, 2006 my clutch started to slip a couple of days ago in my supra, it doesnt do it when you drive slow just under load when you accelerate. is this likely to mean i need a new clutch? or could there be another reason as its only a couple of years old. also if i catch it quick should my flywheel be ok? many thanks in advance Quote Link to comment Share on other sites More sharing options...
Guest dee_rz Posted September 9, 2006 Share Posted September 9, 2006 sounds likely bud Quote Link to comment Share on other sites More sharing options...
jaiscossie Posted September 10, 2006 Author Share Posted September 10, 2006 so its likely i need a new one then? had a quote of £400 fitted for a totota one does this seem a good price? Quote Link to comment Share on other sites More sharing options...
Jonty Posted September 10, 2006 Share Posted September 10, 2006 It might need adjusting - so you should check this checked out first before committing to a new clutch. The new type of clutch you buy is important as it depends on the power you are running now or plan to upgrade to. SUggested Paul Whif or J Japanese can sort this for you - try turbo fit in Milton Keynes? Jonathan Quote Link to comment Share on other sites More sharing options...
jaiscossie Posted September 10, 2006 Author Share Posted September 10, 2006 how can yoo adjust them pls? is it not on a self adjusting mechanism? Quote Link to comment Share on other sites More sharing options...
bromy Posted September 10, 2006 Share Posted September 10, 2006 £400 that is a good price, be sure to get the release bearing done too, it wont be the adjustment as it is a hydraulic clutch Quote Link to comment Share on other sites More sharing options...
